跳转到主内容
修复你的物品
维修的权力
商店
简介
If the battery within your Game Boy Advanced SP doesn’t last long, or if the console does not turn on at all, you might need to replace it. The following process applies to both the AGS - 100 and the AGS - 101 models of the console. If the battery has never been replaced, be careful when disassembling the unit, because the battery may have swelled over time which can be a potential hazard. Additionally, make sure that the console is not connected to a power source while performing the battery replacement process.
For a replacement battery, visit Amazon.
  1. Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Lift the battery cover up and remove it from the device.
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Use your fingers or a plastic opening tool to remove the battery from the device.
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
结论
For reassembly, follow the instructions in reverse order.
20等其他人完成本指南。
Rocco Lattanzio
于2013年01月11日注册
778 信誉积分
创作了2篇指南
团队
Cal Poly, Team 17-22, Forte Winter 2013 Cal Poly, Team 17-22, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G22
4 名成员
创作了32篇指南
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Santi12008 - 回复
Thanks for yout guideline. I settle in 5 minutes.
aam9999 - 回复
添加评论
浏览统计数据:
过去的24小时: 15
过去的7天: 111
过去的30天: 548
总计 31,122
