跳转到主内容
Nintendo Game Boy Advance SP Battery Replacement
你所需要的
  1. Nintendo Game Boy Advance SP Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Battery Replacement: 步骤 2 中的图像 1,1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Battery Replacement: 步骤 3 中的图像 1,1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
结论
For reassembly, follow the instructions in reverse order.
32等其他人完成本指南。
Rocco Lattanzio
于01/11/13注册
1,027 声望
创作了2篇指南
团队
Cal Poly, Team 17-22, Forte Winter 2013 Cal Poly, Team 17-22, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G22
4 名成员
创作了41篇指南
3指南评论
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Santi12008 - 回复
Why so pedantic?
keegan clow -
Thanks for yout guideline. I settle in 5 minutes.
aam9999 - 回复
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 149
过去 30 天: 733
总计 77,252
