跳转到主内容
Nintendo Family Computer (Famicom) Controller Motherboard Replacement
你所需要的
  1. Nintendo Family Computer (Famicom) Controller Motherboard Replacement, Controller Motherboard: 步骤 1 中的图像 1,2 Nintendo Family Computer (Famicom) Controller Motherboard Replacement, Controller Motherboard: 步骤 1 中的图像 2,2
    • Use a Phillips screwdriver to remove the six 13.5 mm screws that secure the lower case.
    • Remove the lower case.
  2. Nintendo Family Computer (Famicom) Controller Motherboard Replacement: 步骤 2 中的图像 1,2 Nintendo Family Computer (Famicom) Controller Motherboard Replacement: 步骤 2 中的图像 2,2
    • Carefully disconnect the faulty controller's connector from the motherboard port.
    • Pull only on the connector; do not pull on the wires. The connector can be quite strenuous to remove. A pry tool or pliers may be helpful to disconnect the connector.
  3. Nintendo Family Computer (Famicom) Controller Motherboard Replacement: 步骤 3 中的图像 1,2 Nintendo Family Computer (Famicom) Controller Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips screwdriver to remove the six 9.3 mm screws from the back side of the controller.
    • Remove the back cover of the controller.
  4. Nintendo Family Computer (Famicom) Controller Motherboard Replacement: 步骤 4 中的图像 1,2 Nintendo Family Computer (Famicom) Controller Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the controller motherboard, noting its orientation.
    • The Player 1 and Player 2 controller motherboards are not identical and differ from one another.
结论
Trenton Saint
于04/02/24注册
109 声望
撰写一个指南
团队
IUPUI, Team 2-2, Harley Spring 2024 IUPUI, Team 2-2, Harley Spring 2024 的会员
IUPUI-HARLEY-S24S2G2
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 35
总计 487
