跳转到主内容
Nintendo Entertainment System cartridge cover replacement
你所需要的
  1. Nintendo Entertainment System cartridge cover replacement, Removing housing: 步骤 1 中的图像 1,2 Nintendo Entertainment System cartridge cover replacement, Removing housing: 步骤 1 中的图像 2,2
    • Remove the six 13.50mm PH2 screws from the base plate.
    • The screws are countersunk 40mm into the base plate.
    • Now take off the upper part of the housing.
  2. Nintendo Entertainment System cartridge cover replacement, Cartridge cover: 步骤 2 中的图像 1,3 Nintendo Entertainment System cartridge cover replacement, Cartridge cover: 步骤 2 中的图像 2,3 Nintendo Entertainment System cartridge cover replacement, Cartridge cover: 步骤 2 中的图像 3,3
    • Take the top housing and turn it over.
    • Remove the four 7,80mm flathead screws.
    • Remove both metal clips.
    • If the flap does not stay open properly, you can bend the clips with pliers.
  3. Nintendo Entertainment System cartridge cover replacement, Cover Flap: 步骤 3 中的图像 1,3 Nintendo Entertainment System cartridge cover replacement, Cover Flap: 步骤 3 中的图像 2,3 Nintendo Entertainment System cartridge cover replacement, Cover Flap: 步骤 3 中的图像 3,3
    • Pull the front black cap off upwards.
    • Now lift the flap out at an angle.
    • The new flap can now be inserted.
结论
Work the steps in reverse order to reassemble your device.
另外一个人完成了本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
TimedIn
于01/10/20注册
981 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 44
总计 1,910
