跳转到主内容
Nintendo Entertainment System Springs Not Properly Mounted on Cartridge Tray Replacement
你所需要的
  1. Nintendo Entertainment System Springs Not Properly Mounted on Cartridge Tray Replacement, Game Cartridge Tray: 步骤 1 中的图像 1,2 Nintendo Entertainment System Springs Not Properly Mounted on Cartridge Tray Replacement, Game Cartridge Tray: 步骤 1 中的图像 2,2
    • Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
    • The screws are recessed about 40 mm.
    • Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
  2. Nintendo Entertainment System Springs Not Properly Mounted on Cartridge Tray Replacement: 步骤 2 中的图像 1,2 Nintendo Entertainment System Springs Not Properly Mounted on Cartridge Tray Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver.
    • Remove the metal cover by pulling it up and away from the rest of the console with your hands.
  3. Nintendo Entertainment System Springs Not Properly Mounted on Cartridge Tray Replacement: 步骤 3 中的图像 1,3 Nintendo Entertainment System Springs Not Properly Mounted on Cartridge Tray Replacement: 步骤 3 中的图像 2,3 Nintendo Entertainment System Springs Not Properly Mounted on Cartridge Tray Replacement: 步骤 3 中的图像 3,3
    • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
  4. Nintendo Entertainment System Springs Not Properly Mounted on Cartridge Tray Replacement: 步骤 4 中的图像 1,2 Nintendo Entertainment System Springs Not Properly Mounted on Cartridge Tray Replacement: 步骤 4 中的图像 2,2
    • Note: Underneath the cartridge tray is a black trapezoid-shaped tab/lip (see marker). When properly assembled this tab/lip goes below the motherboard and shielding as seen here.
    • During reassembly, make sure you orient this tab underneath the motherboard in addition to orienting the tray on top. Failure to do so will bow the cartridge tray and place stress on the component, causing the cartridge spring mechanism to bind.
  5. Nintendo Entertainment System Springs Not Properly Mounted on Cartridge Tray Replacement, Springs Not Properly Mounted on Cartridge Tray: 步骤 5 中的图像 1,1
    • Use your fingernail to squeeze down on one side of the spring and reposition the spring back on to the plastic nipple attached to the smaller part of the game cartridge frame.
结论
4等其他人完成本指南。
nicholasweiser
于09/22/10注册
2,757 声望
创作了6篇指南
团队
Cal Poly, Team 14-40, Forte Fall 2010 Cal Poly, Team 14-40, Forte Fall 2010 的会员
CPSU-FORTE-F10S14G40
4 名成员
创作了28篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 28
总计 8,872
