跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Nintendo Entertainment System Game Cartridge Tray Replacement
你所需要的
  1. Nintendo Entertainment System Game Cartridge Tray Replacement, Game Cartridge Tray: 步骤 1 中的图像 1,2 Nintendo Entertainment System Game Cartridge Tray Replacement, Game Cartridge Tray: 步骤 1 中的图像 2,2
    • Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
    • The screws are recessed about 40 mm.
    • Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
  2. Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 2 中的图像 1,2 Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver.
    • Remove the metal cover by pulling it up and away from the rest of the console with your hands.
  3. Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 3 中的图像 1,3 Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 3 中的图像 2,3 Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 3 中的图像 3,3
    • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
  4. Nintendo Entertainment System Game Cartridge Tray Replacement: 步骤 4 中的图像 1,1
    • Underneath the cartridge tray is a black tab/lip (see marker).
    • Make sure you orient this tab underneath the motherboard in addition to orienting the tray on top. Failure to do so will bow the cartridge tray and place stress on the component.
结论
8等其他人完成本指南。
nicholasweiser
于09/22/10注册
2,634 声望
创作了6篇指南
团队
Cal Poly, Team 14-40, Forte Fall 2010 Cal Poly, Team 14-40, Forte Fall 2010 的会员
CPSU-FORTE-F10S14G40
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 23
过去 30 天: 95
总计 14,975
