跳转到主内容
Nintendo Entertainment System Disassembly
你所需要的
  1. Nintendo Entertainment System Disassembly, Remove Top Housing: 步骤 1 中的图像 1,2 Nintendo Entertainment System Disassembly, Remove Top Housing: 步骤 1 中的图像 2,2
    • Remove six 13.25mm Phillips screws on the bottom of the system.
    • The screws are recessed about 40mm.
    • Once all screws are removed, simply lift the bottom half away from the top housing.
  2. Nintendo Entertainment System Disassembly, Remove Top RF Shield: 步骤 2 中的图像 1,3 Nintendo Entertainment System Disassembly, Remove Top RF Shield: 步骤 2 中的图像 2,3 Nintendo Entertainment System Disassembly, Remove Top RF Shield: 步骤 2 中的图像 3,3
    • Remove seven 13.25mm Phillips screws around the perimeter of the RF shield.
    • Lift the RF shield up and away from the system and place aside.
  3. Nintendo Entertainment System Disassembly, Remove Cartridge Tray: 步骤 3 中的图像 1,3 Nintendo Entertainment System Disassembly, Remove Cartridge Tray: 步骤 3 中的图像 2,3 Nintendo Entertainment System Disassembly, Remove Cartridge Tray: 步骤 3 中的图像 3,3
    • Remove four 13.25mm Phillips screws from the four corners of the cartridge tray.
    • Your system may only have two screws on the bottom.
    • Remove two 17.25mm Phillips screws from the top of cartridge tray.
    • Once free, slide the cartridge tray towards you and then lift slightly in the front to remove.
  4. Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 1: 步骤 4 中的图像 1,3 Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 1: 步骤 4 中的图像 2,3 Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 1: 步骤 4 中的图像 3,3
    • Remove three 13.25mm Phillips screws to free the motherboard from the bottom housing.
    • Carefully lift the motherboard and turn it over to find the wired connections.
  5. Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 2: 步骤 5 中的图像 1,2 Nintendo Entertainment System Disassembly, Remove Motherboard Pt. 2: 步骤 5 中的图像 2,2
    • Disconnect the wired connections from the motherboard.
    • Player 1 (Shorter wires)
    • Player 2 (Longer wires)
    • Power/Reset Buttons
  6. Nintendo Entertainment System Disassembly, Remove Bottom RF Shield: 步骤 6 中的图像 1,2 Nintendo Entertainment System Disassembly, Remove Bottom RF Shield: 步骤 6 中的图像 2,2
    • The bottom RF shield is held on by tension around the expansion port. Lift the shield up and away from the motherboard.
  7. Nintendo Entertainment System Disassembly, Remove 72-Pin Connector: 步骤 7 中的图像 1,2 Nintendo Entertainment System Disassembly, Remove 72-Pin Connector: 步骤 7 中的图像 2,2
    • To remove the 72-Pin connector, apply force to each edge and slide the connector off the contacts on the motherboard.
  8. Nintendo Entertainment System Disassembly, Remove Power/Reset Buttons: 步骤 8 中的图像 1,2 Nintendo Entertainment System Disassembly, Remove Power/Reset Buttons: 步骤 8 中的图像 2,2
    • Remove two 13.25mm Phillips screws from the button assembly. Lift slightly in the back and then up and away from the housing to remove.
  9. Nintendo Entertainment System Disassembly, Remove Controller Ports: 步骤 9 中的图像 1,3 Nintendo Entertainment System Disassembly, Remove Controller Ports: 步骤 9 中的图像 2,3 Nintendo Entertainment System Disassembly, Remove Controller Ports: 步骤 9 中的图像 3,3
    • Remove two 7.25mm Phillips screws from the bottom of the system. Lift the controller port faceplate up and away.
    • Remove the controller ports by feeding them through the port holes to the front of the housing.
    • When reassembling, Player 1 (Left) has shorter wires that Player 2 (Right).
  10. Nintendo Entertainment System Disassembly, Remove Plastic Door and Accent Pieces: 步骤 10 中的图像 1,3 Nintendo Entertainment System Disassembly, Remove Plastic Door and Accent Pieces: 步骤 10 中的图像 2,3 Nintendo Entertainment System Disassembly, Remove Plastic Door and Accent Pieces: 步骤 10 中的图像 3,3
    • Remove seven 7.25mm small flathead screws from the inside of the top housing.
    • Two of these screws also hold a spring for the door. When reassembling, refer to the keyed shape of the plastic to orient these correctly.
  11. Nintendo Entertainment System Disassembly, Disassembly Complete!: 步骤 11 中的图像 1,2 Nintendo Entertainment System Disassembly, Disassembly Complete!: 步骤 11 中的图像 2,2
    • Screw List
    • (19x) 13.25mm Phillips
    • (2x) 17.25mm Phillips
    • (2x) 7.25mm Phillips (Silver, large cap)
    • (7x) 7.25mm Flathead (Silver, small)
结论
22等其他人完成本指南。
Joe Shacar
于06/01/21注册
1,185 声望
撰写一个指南
5指南评论
Thank you very much!
Haihatsu - 回复
Love step by step
Rene Leon - 回复
Very well done easy to do and easier to follow.
rictic1 - 回复
Perfect just top style
SYNTAX - 回复
Great guide, I wanted to confirm that I had the right screws on me since I had disassembled my NES on a workbench with some other consoles (bad habit).
I thought I was going crazy though since the 13.25mm Phillips screw count is off- it's 20 if you have 2 screws on your cartridge tray, and 22 if you have the 6 screws shown in the guide.
- 6x outer casing
- 7x top RF shield
- 2x or 4x cartridge tray
- 3x lower motherboard
- 2x power/reset button assembly
Dylan French - 回复
添加评论
浏览统计数据:
过去 24 小时: 31
过去 7 天: 163
过去 30 天: 758
总计 30,918
