跳转到主内容
Nintendo DSi XL Volume Control Switch Replacement
你所需要的
  1. Nintendo DSi XL Volume Control Switch Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo DSi XL Volume Control Switch Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Volume Control Switch Replacement: 步骤 2 中的图像 1,1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Volume Control Switch Replacement, Lower Case: 步骤 3 中的图像 1,3 Nintendo DSi XL Volume Control Switch Replacement, Lower Case: 步骤 3 中的图像 2,3 Nintendo DSi XL Volume Control Switch Replacement, Lower Case: 步骤 3 中的图像 3,3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Volume Control Switch Replacement: 步骤 4 中的图像 1,1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Volume Control Switch Replacement: 步骤 5 中的图像 1,3 Nintendo DSi XL Volume Control Switch Replacement: 步骤 5 中的图像 2,3 Nintendo DSi XL Volume Control Switch Replacement: 步骤 5 中的图像 3,3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Volume Control Switch Replacement: 步骤 6 中的图像 1,2 Nintendo DSi XL Volume Control Switch Replacement: 步骤 6 中的图像 2,2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Volume Control Switch Replacement: 步骤 7 中的图像 1,2 Nintendo DSi XL Volume Control Switch Replacement: 步骤 7 中的图像 2,2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Volume Control Switch Replacement, Left Shoulder Button: 步骤 8 中的图像 1,3 Nintendo DSi XL Volume Control Switch Replacement, Left Shoulder Button: 步骤 8 中的图像 2,3 Nintendo DSi XL Volume Control Switch Replacement, Left Shoulder Button: 步骤 8 中的图像 3,3
    • Remove the two gold 4.0 mm Phillips screws securing the left shoulder button assembly to the lower case.
    • Lift the left shoulder button assembly from the lower case.
    • The components of the left shoulder button assembly:
    • Left shoulder button
    • Shoulder button spring
    • Retaining pin
    • Left shoulder button support panel
  9. Nintendo DSi XL Volume Control Switch Replacement, Volume Control Switch: 步骤 9 中的图像 1,1
    • On the inside of the battery compartment, use the tip of a spudger to detach the metal latch securing the volume control switch in place.
    • The latch will only move about 1 mm.
  10. Nintendo DSi XL Volume Control Switch Replacement: 步骤 10 中的图像 1,3 Nintendo DSi XL Volume Control Switch Replacement: 步骤 10 中的图像 2,3 Nintendo DSi XL Volume Control Switch Replacement: 步骤 10 中的图像 3,3
    • Using the flat end of a spudger, remove the adhesive securing the volume control switch ribbon cable to the back of the battery compartment.
    • Using the flat of a spudger, pry the volume control switch straight up out of the lower case.
    • Remove the volume control switch from the DSi XL.
  11. Nintendo DSi XL Volume Control Switch Replacement: 步骤 11 中的图像 1,1
    • Using the flat end of a spudger, remove the volume control buttons from the metal backing bracket.
    • The bracket is attached by a strong adhesive. Work slowly and carefully, being sure to not damage the ribbon cable.
    • Volume control switch remains.
结论
2等其他人完成本指南。
Brett Hartt
于04/12/10注册
130,037 声望
创作了143篇指南
团队
iFixit iFixit 的会员
Staff
120 名成员
创作了20,169篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 18
总计 6,287
