跳转到主内容
加入维修社区 - 创建账户
Nintendo DSi XL Volume Buttons Replacement
你所需要的
  1. Nintendo DSi XL Volume Buttons Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo DSi XL Volume Buttons Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Volume Buttons Replacement: 步骤 2 中的图像 1,1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Volume Buttons Replacement, Lower Case: 步骤 3 中的图像 1,3 Nintendo DSi XL Volume Buttons Replacement, Lower Case: 步骤 3 中的图像 2,3 Nintendo DSi XL Volume Buttons Replacement, Lower Case: 步骤 3 中的图像 3,3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Volume Buttons Replacement: 步骤 4 中的图像 1,1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Volume Buttons Replacement: 步骤 5 中的图像 1,3 Nintendo DSi XL Volume Buttons Replacement: 步骤 5 中的图像 2,3 Nintendo DSi XL Volume Buttons Replacement: 步骤 5 中的图像 3,3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Volume Buttons Replacement: 步骤 6 中的图像 1,2 Nintendo DSi XL Volume Buttons Replacement: 步骤 6 中的图像 2,2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Volume Buttons Replacement: 步骤 7 中的图像 1,2 Nintendo DSi XL Volume Buttons Replacement: 步骤 7 中的图像 2,2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Volume Buttons Replacement, Volume Control Switch: 步骤 8 中的图像 1,1
    • On the inside of the battery compartment, use the tip of a spudger to detach the metal latch securing the volume control switch in place.
    • The latch will only move about 1 mm.
  9. Nintendo DSi XL Volume Buttons Replacement: 步骤 9 中的图像 1,3 Nintendo DSi XL Volume Buttons Replacement: 步骤 9 中的图像 2,3 Nintendo DSi XL Volume Buttons Replacement: 步骤 9 中的图像 3,3
    • Using the flat end of a spudger, remove the adhesive securing the volume control switch ribbon cable to the back of the battery compartment.
    • Using the flat of a spudger, pry the volume control switch straight up out of the lower case.
    • Remove the volume control switch from the DSi XL.
  10. Nintendo DSi XL Volume Buttons Replacement: 步骤 10 中的图像 1,1
    • Using the flat end of a spudger, remove the volume control buttons from the metal backing bracket.
    • The bracket is attached by a strong adhesive. Work slowly and carefully, being sure to not damage the ribbon cable.
    • Volume control switch remains.
  11. Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: 步骤 11 中的图像 1,3 Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: 步骤 11 中的图像 2,3 Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • While pushing the volume buttons through their holes in the lower case, remove the buttons and their silicone pads with a pair of tweezers.
    • Work patiently and carefully as the silicone pad is easily torn.
    • Remove the buttons from the silicone pad.
结论
另外一个人完成了本指南。
Brett Hartt
于04/12/10注册
131,447 声望
创作了144篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了24,043篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 56
过去 30 天: 213
总计 8,372
