跳转到主内容
Nintendo DSi XL Upper Screen Replacement
你所需要的
  1. Nintendo DSi XL Upper Screen Replacement, Rear Bezel: 步骤 1 中的图像 1,3 Nintendo DSi XL Upper Screen Replacement, Rear Bezel: 步骤 1 中的图像 2,3 Nintendo DSi XL Upper Screen Replacement, Rear Bezel: 步骤 1 中的图像 3,3
    • Use a push pin to remove the four plastic screw covers on the front bezel.
  2. Nintendo DSi XL Upper Screen Replacement: 步骤 2 中的图像 1,1
    • Remove four Phillips screws securing the front bezel to the rear bezel.
  3. Nintendo DSi XL Upper Screen Replacement: 步骤 3 中的图像 1,2 Nintendo DSi XL Upper Screen Replacement: 步骤 3 中的图像 2,2
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  4. Nintendo DSi XL Upper Screen Replacement: 步骤 4 中的图像 1,2 Nintendo DSi XL Upper Screen Replacement: 步骤 4 中的图像 2,2
    • Insert a spudger into the gap between the front and rear bezel
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  5. Nintendo DSi XL Upper Screen Replacement: 步骤 5 中的图像 1,1
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  6. Nintendo DSi XL Upper Screen Replacement: 步骤 6 中的图像 1,1
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  7. Nintendo DSi XL Upper Screen Replacement: 步骤 7 中的图像 1,1
    • Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Remove the rear bezel.
  8. Nintendo DSi XL Upper Screen Replacement, Upper Screen: 步骤 8 中的图像 1,1
    • Using the flat end of a spudger, pry the Wi-Fi antenna out of its housing from within the front bezel and move it aside.
  9. Nintendo DSi XL Upper Screen Replacement: 步骤 9 中的图像 1,3 Nintendo DSi XL Upper Screen Replacement: 步骤 9 中的图像 2,3 Nintendo DSi XL Upper Screen Replacement: 步骤 9 中的图像 3,3
    • Using the flat end of a spudger, pry the left speaker out of its socket on the front bezel.
    • De-route the speaker cable along the top edge of the screen.
    • Work carefully and slowly, holding onto the wire and not the speaker itself. The solder joints may break if pulled on too hard.
    • In the same manner as described above, remove the right speaker from its socket on the front bezel.
    • Place both speakers on the back of the upper LCD.
  10. Nintendo DSi XL Upper Screen Replacement: 步骤 10 中的图像 1,1
    • Open the DSi XL.
    • Carefully push the upper display assembly through its housing in the front bezel.
    • The upper display assembly is held in place via adhesive to the front bezel. Push firmly, being careful not to break the upper LCD.
    • Rotate the upper display assembly out of the front bezel.
  11. Nintendo DSi XL Upper Screen Replacement: 步骤 11 中的图像 1,2 Nintendo DSi XL Upper Screen Replacement: 步骤 11 中的图像 2,2
    • Insert the flat end of a spudger underneath the adhesive strip that secures the front screen to the upper LCD.
    • Slide the spudger along the bottom side of the upper LCD, freeing the adhesive along that edge.
  12. Nintendo DSi XL Upper Screen Replacement: 步骤 12 中的图像 1,2 Nintendo DSi XL Upper Screen Replacement: 步骤 12 中的图像 2,2
    • In the same manner as previously described, detach the adhesive along the left edge of the upper LCD.
  13. Nintendo DSi XL Upper Screen Replacement: 步骤 13 中的图像 1,2 Nintendo DSi XL Upper Screen Replacement: 步骤 13 中的图像 2,2
    • In the same manner as previously described, detach the adhesive along the right side of the upper LCD.
  14. Nintendo DSi XL Upper Screen Replacement: 步骤 14 中的图像 1,2 Nintendo DSi XL Upper Screen Replacement: 步骤 14 中的图像 2,2
    • Carefully lift the upper screen from the bottom edge.
    • Pull the upper screen away from the upper LCD.
结论
6等其他人完成本指南。
Brett Hartt
于04/12/10注册
130,453 声望
创作了143篇指南
团队
iFixit iFixit 的会员
Staff
119 名成员
创作了21,995篇指南
5指南评论
This step-through is not complete.....
how do you actually change the screen????
lrj7 - 回复
Yes, you're right. Also there's a gap between steps 7 to 8 because you cannot actually detach the upper screen without disconnect the board cable from the lower screen part.
By the way, I can't quite successfuly open the upper screen part on my dsi xl because it dont seem to give any space between the two covers. Any suggestions?
Luis Fernando Ocampo Sanchez -
@Irj7 find the top lcd replacement guide here:
Nintendo DSi XL Upper LCD Replacement
James Bourne - 回复
NOTE To others out there… this guide is only to change the plastic cover over the screen, and not the screen itself. See James Bourne’s link for the real “how to replace upper LCD” guide.
virtue - 回复
Does anyone know what the material is in the upper shell (behind the LCD screen) link. I looks like some kind of foam pad?
Andy Poes - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 101
总计 34,047
