跳转到主内容
Nintendo DSi XL SD Board Replacement
你所需要的
  1. Nintendo DSi XL SD Board Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo DSi XL SD Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL SD Board Replacement: 步骤 2 中的图像 1,1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL SD Board Replacement, Lower Case: 步骤 3 中的图像 1,3 Nintendo DSi XL SD Board Replacement, Lower Case: 步骤 3 中的图像 2,3 Nintendo DSi XL SD Board Replacement, Lower Case: 步骤 3 中的图像 3,3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL SD Board Replacement: 步骤 4 中的图像 1,1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL SD Board Replacement: 步骤 5 中的图像 1,3 Nintendo DSi XL SD Board Replacement: 步骤 5 中的图像 2,3 Nintendo DSi XL SD Board Replacement: 步骤 5 中的图像 3,3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL SD Board Replacement: 步骤 6 中的图像 1,2 Nintendo DSi XL SD Board Replacement: 步骤 6 中的图像 2,2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL SD Board Replacement: 步骤 7 中的图像 1,2 Nintendo DSi XL SD Board Replacement: 步骤 7 中的图像 2,2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL SD Board Replacement, Right Shoulder Button: 步骤 8 中的图像 1,3 Nintendo DSi XL SD Board Replacement, Right Shoulder Button: 步骤 8 中的图像 2,3 Nintendo DSi XL SD Board Replacement, Right Shoulder Button: 步骤 8 中的图像 3,3
    • Remove the two gold 4.0 mm Phillips screws securing the right shoulder button assembly to the back case.
    • Lift the right shoulder button assembly from the back case.
    • The components of the right shoulder button assembly:
    • Right shoulder button
    • Shoulder button spring
    • Retaining pin
    • Right shoulder button holding panel
  9. Nintendo DSi XL SD Board Replacement, Stylus Housing: 步骤 9 中的图像 1,1
    • Remove the stylus from its housing on the right side of the DSi XL.
  10. Nintendo DSi XL SD Board Replacement: 步骤 10 中的图像 1,3 Nintendo DSi XL SD Board Replacement: 步骤 10 中的图像 2,3 Nintendo DSi XL SD Board Replacement: 步骤 10 中的图像 3,3
    • Remove the three 4 mm gold Phillips screws securing the stylus housing to the lower case.
    • Using a spudger, lift the stylus housing off the lower case.
    • Remove the stylus housing from the handheld console.
  11. Nintendo DSi XL SD Board Replacement, SD Board: 步骤 11 中的图像 1,1
    • Lift the SD board off the lower case.
结论
另外一个人完成了本指南。
Brett Hartt
于04/12/10注册
130,037 声望
创作了143篇指南
团队
iFixit iFixit 的会员
Staff
120 名成员
创作了20,157篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 77
总计 8,587
