跳转到主内容
Nintendo DSi XL Right Shoulder Button Replacement
你所需要的
  1. Nintendo DSi XL Right Shoulder Button Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo DSi XL Right Shoulder Button Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Right Shoulder Button Replacement: 步骤 2 中的图像 1,1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Right Shoulder Button Replacement, Lower Case: 步骤 3 中的图像 1,3 Nintendo DSi XL Right Shoulder Button Replacement, Lower Case: 步骤 3 中的图像 2,3 Nintendo DSi XL Right Shoulder Button Replacement, Lower Case: 步骤 3 中的图像 3,3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Right Shoulder Button Replacement: 步骤 4 中的图像 1,1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Right Shoulder Button Replacement: 步骤 5 中的图像 1,3 Nintendo DSi XL Right Shoulder Button Replacement: 步骤 5 中的图像 2,3 Nintendo DSi XL Right Shoulder Button Replacement: 步骤 5 中的图像 3,3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Right Shoulder Button Replacement: 步骤 6 中的图像 1,2 Nintendo DSi XL Right Shoulder Button Replacement: 步骤 6 中的图像 2,2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Right Shoulder Button Replacement: 步骤 7 中的图像 1,2 Nintendo DSi XL Right Shoulder Button Replacement: 步骤 7 中的图像 2,2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Right Shoulder Button Replacement, Right Shoulder Button: 步骤 8 中的图像 1,3 Nintendo DSi XL Right Shoulder Button Replacement, Right Shoulder Button: 步骤 8 中的图像 2,3 Nintendo DSi XL Right Shoulder Button Replacement, Right Shoulder Button: 步骤 8 中的图像 3,3
    • Remove the two gold 4.0 mm Phillips screws securing the right shoulder button assembly to the back case.
    • Lift the right shoulder button assembly from the back case.
    • The components of the right shoulder button assembly:
    • Right shoulder button
    • Shoulder button spring
    • Retaining pin
    • Right shoulder button holding panel
结论
另外一个人完成了本指南。
Brett Hartt
于04/12/10注册
127,941 声望
创作了143篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,299篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 94
总计 9,297
