跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Nintendo DSi XL Power Board Replacement
你所需要的
  1. Nintendo DSi XL Power Board Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo DSi XL Power Board Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Power Board Replacement: 步骤 2 中的图像 1,1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Power Board Replacement, Lower Case: 步骤 3 中的图像 1,3 Nintendo DSi XL Power Board Replacement, Lower Case: 步骤 3 中的图像 2,3 Nintendo DSi XL Power Board Replacement, Lower Case: 步骤 3 中的图像 3,3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Power Board Replacement: 步骤 4 中的图像 1,1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Power Board Replacement: 步骤 5 中的图像 1,3 Nintendo DSi XL Power Board Replacement: 步骤 5 中的图像 2,3 Nintendo DSi XL Power Board Replacement: 步骤 5 中的图像 3,3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Power Board Replacement: 步骤 6 中的图像 1,2 Nintendo DSi XL Power Board Replacement: 步骤 6 中的图像 2,2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Power Board Replacement: 步骤 7 中的图像 1,2 Nintendo DSi XL Power Board Replacement: 步骤 7 中的图像 2,2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Power Board Replacement, Power Board: 步骤 8 中的图像 1,2 Nintendo DSi XL Power Board Replacement, Power Board: 步骤 8 中的图像 2,2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
    • With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
  9. Nintendo DSi XL Power Board Replacement: 步骤 9 中的图像 1,1
    • Using the flat end of the spudger, carefully pry the battery cable out of its socket on the motherboard.
    • Use caution, as the wires are very fragile and could come out of the connector if pulled on too hard.
  10. Nintendo DSi XL Power Board Replacement: 步骤 10 中的图像 1,2 Nintendo DSi XL Power Board Replacement: 步骤 10 中的图像 2,2
    • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
    • Lift the power board off the upper case.
结论
6等其他人完成本指南。
Brett Hartt
于04/12/10注册
127,876 声望
创作了143篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,734篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 66
总计 17,011
