跳转到主内容
Nintendo DSi XL Lower Case Replacement
你所需要的
  1. Nintendo DSi XL Lower Case Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo DSi XL Lower Case Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Lower Case Replacement: 步骤 2 中的图像 1,1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Lower Case Replacement, Lower Case: 步骤 3 中的图像 1,3 Nintendo DSi XL Lower Case Replacement, Lower Case: 步骤 3 中的图像 2,3 Nintendo DSi XL Lower Case Replacement, Lower Case: 步骤 3 中的图像 3,3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Lower Case Replacement: 步骤 4 中的图像 1,1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Lower Case Replacement: 步骤 5 中的图像 1,3 Nintendo DSi XL Lower Case Replacement: 步骤 5 中的图像 2,3 Nintendo DSi XL Lower Case Replacement: 步骤 5 中的图像 3,3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Lower Case Replacement: 步骤 6 中的图像 1,2 Nintendo DSi XL Lower Case Replacement: 步骤 6 中的图像 2,2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Lower Case Replacement: 步骤 7 中的图像 1,2 Nintendo DSi XL Lower Case Replacement: 步骤 7 中的图像 2,2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
结论
6等其他人完成本指南。
David Hodson
于04/13/10注册
153,454 声望
创作了127篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 104
总计 9,873
