跳转到主内容
Nintendo DSi XL Hinges Replacement
你所需要的
  1. Nintendo DSi XL Hinges Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo DSi XL Hinges Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Hinges Replacement: 步骤 2 中的图像 1,1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Hinges Replacement, Wi-Fi Board: 步骤 3 中的图像 1,2 Nintendo DSi XL Hinges Replacement, Wi-Fi Board: 步骤 3 中的图像 2,2
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  4. Nintendo DSi XL Hinges Replacement: 步骤 4 中的图像 1,1
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
  5. Nintendo DSi XL Hinges Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
  6. Nintendo DSi XL Hinges Replacement: 步骤 6 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 6 中的图像 2,2
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  7. Nintendo DSi XL Hinges Replacement: 步骤 7 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 7 中的图像 2,2
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  8. Nintendo DSi XL Hinges Replacement: 步骤 8 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 8 中的图像 2,2
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  9. Nintendo DSi XL Hinges Replacement: 步骤 9 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 9 中的图像 2,2
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
  10. Nintendo DSi XL Hinges Replacement: 步骤 10 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 10 中的图像 2,2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  11. Nintendo DSi XL Hinges Replacement: 步骤 11 中的图像 1,1
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
  12. Nintendo DSi XL Hinges Replacement: 步骤 12 中的图像 1,1
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
  13. Nintendo DSi XL Hinges Replacement: 步骤 13 中的图像 1,1
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  14. Nintendo DSi XL Hinges Replacement: 步骤 14 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 14 中的图像 2,2
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  15. Nintendo DSi XL Hinges Replacement: 步骤 15 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 15 中的图像 2,2
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
  16. Nintendo DSi XL Hinges Replacement, Lower Display Assembly: 步骤 16 中的图像 1,2 Nintendo DSi XL Hinges Replacement, Lower Display Assembly: 步骤 16 中的图像 2,2
    • With the console still upside-down, open the DSi XL slightly.
    • Push the lower display away from the upper case.
    • Remove the lower display from the DSi XL.
  17. Nintendo DSi XL Hinges Replacement, Rear Bezel: 步骤 17 中的图像 1,3 Nintendo DSi XL Hinges Replacement, Rear Bezel: 步骤 17 中的图像 2,3 Nintendo DSi XL Hinges Replacement, Rear Bezel: 步骤 17 中的图像 3,3
    • Turn the DSi XL over and open the display.
    • When re-assembling the device, be sure to re-install the ABXY and Start/Select buttons, as they are likely to fall out once the handheld console is turned over.
    • Use a pushpin to remove the four plastic screw covers on the front bezel.
  18. Nintendo DSi XL Hinges Replacement: 步骤 18 中的图像 1,1
    • Remove the four 3.5 mm silver Phillips screws securing the rear bezel to the front bezel.
  19. Nintendo DSi XL Hinges Replacement: 步骤 19 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 19 中的图像 2,2
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  20. Nintendo DSi XL Hinges Replacement: 步骤 20 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 20 中的图像 2,2
    • Insert a spudger into the gap between the front and rear bezel.
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  21. Nintendo DSi XL Hinges Replacement: 步骤 21 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 21 中的图像 2,2
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  22. Nintendo DSi XL Hinges Replacement: 步骤 22 中的图像 1,1
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  23. Nintendo DSi XL Hinges Replacement: 步骤 23 中的图像 1,1
    • Using the flat end of a spudger, pry the rear camera off the rear bezel.
    • Remove the rear bezel.
  24. Nintendo DSi XL Hinges Replacement, Wi-Fi Antenna: 步骤 24 中的图像 1,2 Nintendo DSi XL Hinges Replacement, Wi-Fi Antenna: 步骤 24 中的图像 2,2
    • Remove the Phillips screw holding the metal securing bracket in place.
    • Lift the metal bracket off the camera.
  25. Nintendo DSi XL Hinges Replacement: 步骤 25 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 25 中的图像 2,2
    • Lift the Wi-Fi antenna off the front display bezel.
    • De-route the Wi-Fi antenna cable from its grooves at the bottom of the front display bezel.
  26. Nintendo DSi XL Hinges Replacement: 步骤 26 中的图像 1,3 Nintendo DSi XL Hinges Replacement: 步骤 26 中的图像 2,3 Nintendo DSi XL Hinges Replacement: 步骤 26 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Pull the Wi-Fi antenna cable through the right hinge connecting the front bezel and upper case.
    • Use the pointed end of a spudger to guide the connector at the end of the Wi-Fi antenna cable through the hinge.
    • To replace the antenna, use a pair of tweezers to guide the connector through the hinge.
  27. Nintendo DSi XL Hinges Replacement, Front Bezel Assembly: 步骤 27 中的图像 1,3 Nintendo DSi XL Hinges Replacement, Front Bezel Assembly: 步骤 27 中的图像 2,3 Nintendo DSi XL Hinges Replacement, Front Bezel Assembly: 步骤 27 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Close the DSi XL and turn it over.
    • Using a pair of tweezers, pull the microphone out of its housing in the front bezel.
    • De-route the microphone cable, and pull it through the right hinge.
  28. Nintendo DSi XL Hinges Replacement: 步骤 28 中的图像 1,3 Nintendo DSi XL Hinges Replacement: 步骤 28 中的图像 2,3 Nintendo DSi XL Hinges Replacement: 步骤 28 中的图像 3,3
    • Using the flat end of a spudger, pry the left speaker out of its socket on the front bezel.
    • De-route the speaker cable along the top edge of the screen.
    • Work carefully and slowly, holding onto the wire and not the speaker itself. The solder joints may break if pulled on too hard.
    • In the same manner described above, remove the right speaker from its socket on the front bezel.
    • Place both speakers on the back of the upper LCD.
  29. Nintendo DSi XL Hinges Replacement: 步骤 29 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 29 中的图像 2,2
    • Ensuring that the upper LCD does not fall out of the front bezel, turn the DSi XL over.
    • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
    • Lift the power board up off the upper case.
  30. Nintendo DSi XL Hinges Replacement: 步骤 30 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 30 中的图像 2,2
    • Peel the rubber button pads off the backside of the D-pad and power button.
  31. Nintendo DSi XL Hinges Replacement: 步骤 31 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 31 中的图像 2,2
    • Open the case slightly.
    • Push the D-pad up through its housing in the upper case. Remove the D-pad.
    • In the same way, remove the power button from the upper case.
  32. Nintendo DSi XL Hinges Replacement: 步骤 32 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 32 中的图像 2,2
    • Using a pair of tweezers, remove the LED diffuser bracket and the LED diffuser from the upper case of the DSi XL.
  33. Nintendo DSi XL Hinges Replacement: 步骤 33 中的图像 1,3 Nintendo DSi XL Hinges Replacement: 步骤 33 中的图像 2,3 Nintendo DSi XL Hinges Replacement: 步骤 33 中的图像 3,3
    • In the following steps, you will be using a spudger to remove the hinge pin from the left side of the DSi XL.
    • Place the tip of a spudger in the LED diffuser compartment, on the face of the clutch hinge.
    • Push the clutch hinge to the left.
    • Some force will be required. You will hear an audible "pop" when the clutch has cleared the lower case. It will move about 0.25".
  34. Nintendo DSi XL Hinges Replacement: 步骤 34 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 34 中的图像 2,2
    • Lift the left side of the front bezel away from the upper case.
    • Do not lift too far, or else the hinge pin will break. Only lift enough to clear the LED compartment, about 1".
    • Pull the front bezel to the left, separating the front bezel from the upper case.
    • Do not attempt to fully separate the two halves yet. There are still ribbon cables running through the upper case.
  35. Nintendo DSi XL Hinges Replacement: 步骤 35 中的图像 1,3 Nintendo DSi XL Hinges Replacement: 步骤 35 中的图像 2,3 Nintendo DSi XL Hinges Replacement: 步骤 35 中的图像 3,3
    • Grasp the camera and upper LCD ribbon cables between your thumb and forefinger, pulling them out of the upper case slightly, slide them down through the slit in the upper case.
    • Rotate the front bezel assembly clockwise so that the ends of the camera and LCD cables slide sideways through the slit in the front bezel.
  36. Nintendo DSi XL Hinges Replacement: 步骤 36 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 36 中的图像 2,2
    • In order to remove the upper LCD and the cameras from the front bezel, it is helpful to coil the ribbon cables together.
    • Carefully coil the two ribbon cables together, so that the connectors are on the inside of the spool.
    • Wrap the ribbon cables tightly, but not too tight, as bending the connectors will render them inoperable.
  37. Nintendo DSi XL Hinges Replacement: 步骤 37 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 37 中的图像 2,2
    • Holding the upper LCD and the cameras together, pull the cables through the hinge in the front bezel.
    • Pull slowly, making sure that the cables do not catch on the hinge pin and tear.
    • Uncoil the ribbon cables.
  38. Nintendo DSi XL Hinges Replacement, Hinges: 步骤 38 中的图像 1,2 Nintendo DSi XL Hinges Replacement, Hinges: 步骤 38 中的图像 2,2
    • Pull the hollow hinge pin out of the right side of the front bezel.
  39. Nintendo DSi XL Hinges Replacement: 步骤 39 中的图像 1,2 Nintendo DSi XL Hinges Replacement: 步骤 39 中的图像 2,2
    • Push the clutch hinge on the left side of the front bezel through its mount bracket.
    • Remove the clutch hinge.
结论
3等其他人完成本指南。
Brett Hartt
于04/12/10注册
128,242 声望
创作了143篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,067篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 29
过去 30 天: 158
总计 23,998
