简介
使用这个指南更换肩键和SD卡槽排线
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
这个步骤还没有翻译 帮忙翻译一下
Lift the steel battery tray out of the lower case and remove the trigger button/SD board assembly.
If your trigger button happens to fall apart during diassembly, the third picture shows its correct installed orientation. Be sure the spring is installed in the position shown, and that the two trigger button covers are unique to the side they are supposed to be installed in.
为了还原你的设备,请反向阅读步骤
为了还原你的设备,请反向阅读步骤
27等其他人完成本指南。
由衷感谢以下译者:
71%
seers正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2条评论
I noticed some pencil marks on the inside of the lower shell that must have come from the factory. There is an m/ to the right of the foam pad, an ax to the right of that, and some kind of numeric marking that says 1T7 12 above the ribbon cable. I'm wondering if it has any significance.
Hi! I accidentally stripped the screws above the game slot , any ideas how to unscrew it without breaking my dsi?
