简介
This guide has been updated by iFixit staff! Read the new, official guide here.
A guide on replacing your Nintendo DSi motherboard.
你所需要的
步骤 1 Battery
注意:步骤 1-2 源自标记为进行中的 指南。
Loosen the two screws on the battery panel. Then lift the panel up to remove it.
L Button.
Top of the battery pack.
To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
One of the feet did break on me, tweezers came in handy for picking it out
I unfolded and sharpened a paperclip. You can use that to stab and hook the rubber without tearing it, as the rubber is thick enough to reseal when reinserted.
Remove the following screws securing the lower case to the body of the DSi:
Six 5.2 mm Phillips #00 screws.
One 2.7 mm Phillips #00 screw.
Impossible d'enlever les vises… trop serré! comment faire?
evrobert03 - 回复
same problem here. maybe try a JIS?
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
步骤 9 Disconnecting Nintendo DSi Battery Board
注意:步骤 9-10 源自标记为进行中的 指南。
Flip up the black latch and disconnect the D-Pad/Power Button ribbon cable.
The connector is two pieces -- a white "male" piece (connected to the wires), and a beige "female" part (soldered to the main board).
There is a small "notch" in the female part, to give you a place to insert a small flat-head screwdriver. Put the corner of your screwdriver in there, and twist it gently to push the white part up (away from the main board). Do not try to pull it to the right (towards the battery board).
If you have not already done so, disconnect the two bottom-LCD ribbon cables from the main board by prying up the black latches and pulling the cable out to the side.
The ribbon cable (marked in blue) for the touch screen is particularly thin and fragile; be careful to avoid bending it more than necessary.
Flip up the latch and remove the touch screen cable.
Flip up the latch and remove the top-screen ribbon cable.
Pry up on the orange cable to disconnect it from the main board, much like the antenna cable on the Wi-Fi module.
Remove 4 Phillips screws from the board.
Lift the main board from the bottom end and flip it over to reveal the last connector.
2等其他人完成本指南。
一条评论
the screwdriver needed is not a phillips #00, but a phillips #0000. I went down to Sears with my DSi and the Craftsman #00 was too large, the Craftsman #0000 (item 41645) fit perfectly, and was only two bucks
