跳转到主内容
Nintendo DSi Lower LCD Assembly Replacement
你所需要的
  1. Nintendo DSi Lower LCD Assembly Replacement, Battery Cover Removal: 步骤 1 中的图像 1,2 Nintendo DSi Lower LCD Assembly Replacement, Battery Cover Removal: 步骤 1 中的图像 2,2
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift it out of the lower case.
    • If it's difficult to grasp, lightly tap the opposite side of the device.
  2. Nintendo DSi Lower LCD Assembly Replacement, Taking out the Battery: 步骤 2 中的图像 1,2 Nintendo DSi Lower LCD Assembly Replacement, Taking out the Battery: 步骤 2 中的图像 2,2
    • Using a spudger tool (or your fingernail), lift up the battery from the top.
    • There's a small tab on the top of the battery to make removal easier.
    • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
    • Grasp the battery and remove it from the DSi.
  3. Nintendo DSi Lower LCD Assembly Replacement, Lower Case Assembly: 步骤 3 中的图像 1,2 Nintendo DSi Lower LCD Assembly Replacement, Lower Case Assembly: 步骤 3 中的图像 2,2
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
  4. Nintendo DSi Lower LCD Assembly Replacement: 步骤 4 中的图像 1,1
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
  5. Nintendo DSi Lower LCD Assembly Replacement: 步骤 5 中的图像 1,3 Nintendo DSi Lower LCD Assembly Replacement: 步骤 5 中的图像 2,3 Nintendo DSi Lower LCD Assembly Replacement: 步骤 5 中的图像 3,3
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi Lower LCD Assembly Replacement: 步骤 6 中的图像 1,2 Nintendo DSi Lower LCD Assembly Replacement: 步骤 6 中的图像 2,2
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Nintendo DSi Lower LCD Assembly Replacement, Wi-Fi Board: 步骤 7 中的图像 1,1
    • Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
  8. Nintendo DSi Lower LCD Assembly Replacement: 步骤 8 中的图像 1,1
    • Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  9. Nintendo DSi Lower LCD Assembly Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
  10. Nintendo DSi Lower LCD Assembly Replacement: 步骤 10 中的图像 1,2 Nintendo DSi Lower LCD Assembly Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
    • Lower touchscreen cable
    • Lower LCD cable
    • Power board cable
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
  11. Nintendo DSi Lower LCD Assembly Replacement: 步骤 11 中的图像 1,2 Nintendo DSi Lower LCD Assembly Replacement: 步骤 11 中的图像 2,2
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
  12. Nintendo DSi Lower LCD Assembly Replacement: 步骤 12 中的图像 1,2 Nintendo DSi Lower LCD Assembly Replacement: 步骤 12 中的图像 2,2
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap.
    • Use the tip of a spudger to pull the dual camera ribbon cable straight out of its socket.
  13. Nintendo DSi Lower LCD Assembly Replacement: 步骤 13 中的图像 1,1
    • With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
  14. Nintendo DSi Lower LCD Assembly Replacement: 步骤 14 中的图像 1,1
    • Remove the following four Phillips screws securing the motherboard to the DSi framework.
    • Three longer screws.
    • One short screw.
    • Pull the microphone and Wi-Fi antenna cables out of the notch cut into the motherboard near the headphone jack.
  15. Nintendo DSi Lower LCD Assembly Replacement: 步骤 15 中的图像 1,3 Nintendo DSi Lower LCD Assembly Replacement: 步骤 15 中的图像 2,3 Nintendo DSi Lower LCD Assembly Replacement: 步骤 15 中的图像 3,3
    • Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons .
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap.
    • Remove the motherboard from the DSi.
  16. Nintendo DSi Lower LCD Assembly Replacement, Lower LCD Assembly: 步骤 16 中的图像 1,2 Nintendo DSi Lower LCD Assembly Replacement, Lower LCD Assembly: 步骤 16 中的图像 2,2
    • Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework.
    • Lift the lower LCD assembly out of the DSi.
结论
9等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 91
总计 11,109
