当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Unscrew the two Phillips screws securing the battery cover to the lower case.
The screws remain captive to the battery cover.
Grasp the battery cover and lift it out of the lower case.
If it's difficult to grasp, lightly tap the opposite side of the device.
Using a spudger tool (or your fingernail), lift up the battery from the top.
There's a small tab on the top of the battery to make removal easier.
The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
Grasp the battery and remove it from the DSi.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
