跳转到主内容
Nintendo DS Lite Wireless Antenna Replacement
你所需要的
  1. Nintendo DS Lite Wireless Antenna Replacement, Nintendo DS Lite Battery Disconnect: 步骤 1 中的图像 1,1
    • Place your device upside down and locate the battery compartment.
    • Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
    • Loosen the screw enough to remove the battery cover but leave the screw in the cover for reassembly.
    • Use only a Phillips screwdriver to remove screw.
  2. Nintendo DS Lite Wireless Antenna Replacement: 步骤 2 中的图像 1,1
    • Slowly remove the battery cover with the iFixit opening tool.
    • Make sure to remove the cover carefully to keep from losing Phillips screw in the cover. It will be needed for reassembly.
  3. Nintendo DS Lite Wireless Antenna Replacement: 步骤 3 中的图像 1,2 Nintendo DS Lite Wireless Antenna Replacement: 步骤 3 中的图像 2,2
    • Use the iFixit opening tool to carefully pry the battery out of the case.
    • After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • For some devices, you may be able to remove the battery by flipping the DS over and letting the battery fall into your hand.
  4. Nintendo DS Lite Wireless Antenna Replacement, Disassembling Nintendo DS Lite Bottom Case: 步骤 4 中的图像 1,1
    • Remove the following seven screws that secure the lower case to the DS Lite:
    • Three silver tri-wing screws (5mm long)
    • One black tri-wing screw (4mm)
    • Two gold Phillips screws (4mm)
    • One silver Phillips screw (3mm)
    • Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
  5. Nintendo DS Lite Wireless Antenna Replacement: 步骤 5 中的图像 1,1
    • On the front edge of the Nintendo DS between the headphone jack plug and volume controls remove the plastic insert (or cartridge) from the lower slot (Slot 2).
  6. Nintendo DS Lite Wireless Antenna Replacement: 步骤 6 中的图像 1,2 Nintendo DS Lite Wireless Antenna Replacement: 步骤 6 中的图像 2,2
    • Flip the unit over so that it is facing right-side up.
    • Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
    • Avoid touching the L and R shoulder buttons, because they easily detach and are difficult to reassemble. Keep the bottom case flat against your workbench to help hold the shoulder buttons in place.
  7. Nintendo DS Lite Wireless Antenna Replacement: 步骤 7 中的图像 1,3 Nintendo DS Lite Wireless Antenna Replacement: 步骤 7 中的图像 2,3 Nintendo DS Lite Wireless Antenna Replacement: 步骤 7 中的图像 3,3
    • Carefully separate the two pieces by hand.
    • The two shoulder buttons are made up of three pieces -- the plastic button, a pin, and a spring. If they accidentally pop out while you are working, study the picture and make sure you put the spring in the correct position.
    • When reassembling the cover, make sure that the power switch caver on the bottom case is in the off (down) position to avoid breakage.
  8. 注意:步骤 8-11 源自标记为进行中的 指南
    Nintendo DS Lite Wireless Antenna Replacement, Motherboard: 步骤 8 中的图像 1,2 Nintendo DS Lite Wireless Antenna Replacement, Motherboard: 步骤 8 中的图像 2,2
    • Locate the two screws that attach the logic board to the device.
    • Unscrew the two Phillips head screws.
  9. Nintendo DS Lite Wireless Antenna Replacement: 步骤 9 中的图像 1,1
    • With a plastic opening tool, gently separate the logic board from the device base.
    • The ribbon cable and two wires are still connected to the logic board.
    • The buttons may fall out, but can easily be put back in place.
  10. Nintendo DS Lite Wireless Antenna Replacement: 步骤 10 中的图像 1,3 Nintendo DS Lite Wireless Antenna Replacement: 步骤 10 中的图像 2,3 Nintendo DS Lite Wireless Antenna Replacement: 步骤 10 中的图像 3,3
    • Flip the logic board over so that the touch screen is facing up.
    • Using metal tweezers, carefully disconnect the other ribbon cable that connects the touch screen with the logic board.
  11. Nintendo DS Lite Wireless Antenna Replacement: 步骤 11 中的图像 1,1
    • Using one finger nail or the plastic opening tool, carefully lift the brown securing flap of the connector. Then disconnect the ribbon cable that connects the logic board to the upper screen.
  12. Nintendo DS Lite Wireless Antenna Replacement, Top Screen: 步骤 12 中的图像 1,2 Nintendo DS Lite Wireless Antenna Replacement, Top Screen: 步骤 12 中的图像 2,2
    • Remove the two Phillips-head screws that hold the hinge in place.
    • Open the system up (just like if you were about to use it normally).
  13. Nintendo DS Lite Wireless Antenna Replacement: 步骤 13 中的图像 1,2 Nintendo DS Lite Wireless Antenna Replacement: 步骤 13 中的图像 2,2
    • After opening it, carefully unhinge them from each other by sliding the bottom piece to the left and the top piece to the right.
    • Be aware that you can pinch wires while doing this, so don't yank it apart.
  14. Nintendo DS Lite Wireless Antenna Replacement: 步骤 14 中的图像 1,1
    • Using a push pin, remove the four rubber bumpers located at the corners of the top screen.
    • After removing the LEDs and pulling apart the hinge, remove the round hinge shaft. This should be in the top screen piece.
  15. Nintendo DS Lite Wireless Antenna Replacement: 步骤 15 中的图像 1,2 Nintendo DS Lite Wireless Antenna Replacement: 步骤 15 中的图像 2,2
    • Unscrew the four Phillips-head screws and remove the top panel.
    • Be careful not to damage the wires and the ribbon cable.
  16. Nintendo DS Lite Wireless Antenna Replacement: 步骤 16 中的图像 1,2 Nintendo DS Lite Wireless Antenna Replacement: 步骤 16 中的图像 2,2
    • Carefully remove the two speakers and the green wireless card from the top panel.
  17. Nintendo DS Lite Wireless Antenna Replacement: 步骤 17 中的图像 1,1
    • Remove the screen by orienting it face down and pushing up on the screen from underneath.
    • Don't press on the screen too hard, or you may crack the screen.
  18. Nintendo DS Lite Wireless Antenna Replacement: 步骤 18 中的图像 1,1
    • Carefully slide the ribbon cable through the clip.
    • Be careful not to damage the ribbon cable by pulling to hard or creasing it.
  19. Nintendo DS Lite Wireless Antenna Replacement, Wireless Antenna: 步骤 19 中的图像 1,1
    • Carefully use a pair of tweezers to remove the wireless antenna.
    • Be careful that you do not damage the ribbon cable when pulling the black antenna wire through the hinge.
结论
另外一个人完成了本指南。
justin chadwick
于01/21/10注册
397 声望
创作了2篇指南
团队
Cal Poly, Team 16-30, Maness Winter 2010 Cal Poly, Team 16-30, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G30
4 名成员
创作了25篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 4,648
