跳转到主内容
简介
This guide will explain how to replace the shoulder buttons on a DS Lite if they are sticking or not working properly.
The tools you’ll need for this task are:
  • Spudger or other flat tool
  • Screwdrivers
    • Phillips
    • Tri-wing
  1. Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
    • Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
  2. Use a spudger to pry out the battery.
    • Use a spudger to pry out the battery.
    • Pry off the rubber feet.
    • Remove the seven screws securing the lower case:
    • Three tri-wing screws
    • One Phillips screw
    • Two gold Phillips screws
    • One black tri-wing screw
  3. Carefully pry the bottom cover off.
    • Carefully pry the bottom cover off.
    • Remove the shoulder buttons by pulling out the metal pegs that secure them to DS.
    • The triggers are held in by tiny metal pegs and springs. Keep track of each piece.
  4. You can now access the micro-button component and replace or repair anything as needed. You can now access the micro-button component and replace or repair anything as needed. You can now access the micro-button component and replace or repair anything as needed.
    • You can now access the micro-button component and replace or repair anything as needed.
结论
To reassemble your device, follow the steps in reverse order after making your repair.
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去的24小时: 6
过去的7天: 50
过去的30天: 166
总计 1,846
