跳转到主内容
Nintendo DS Lite Shoulder Buttons Replacement
你所需要的
  1. Nintendo DS Lite Shoulder Buttons Replacement, Remove the battery cover: 步骤 1 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
  2. Nintendo DS Lite Shoulder Buttons Replacement, Remove the lower case: 步骤 2 中的图像 1,1
    • Use a spudger to pry out the battery.
    • Pry off the rubber feet.
    • Remove the seven screws securing the lower case:
    • Three tri-wing screws
    • One Phillips screw
    • Two gold Phillips screws
    • One black tri-wing screw
  3. Nintendo DS Lite Shoulder Buttons Replacement: 步骤 3 中的图像 1,1
    • Carefully pry the bottom cover off.
    • Remove the shoulder buttons by pulling out the metal pegs that secure them to DS.
    • The triggers are held in by tiny metal pegs and springs. Keep track of each piece.
  4. Nintendo DS Lite Shoulder Buttons Replacement: 步骤 4 中的图像 1,3 Nintendo DS Lite Shoulder Buttons Replacement: 步骤 4 中的图像 2,3 Nintendo DS Lite Shoulder Buttons Replacement: 步骤 4 中的图像 3,3
    • You can now access the micro-button component and replace or repair anything as needed.
结论
To reassemble your device, follow the steps in reverse order after making your repair.
5等其他人完成本指南。
3条评论
For anyone dealing with unresponsive shoulder buttons, I highly recommend watching this video guide;
https://www.youtube.com/watch?v=VnWdawXC...
Gabriel Branyiczky - 回复
たしかにそうですね!!!
kawagoe -
とても、わかりやすくて、しっかり修理できました!
kawagoe - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 61
过去 30 天: 243
总计 6,444
