跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Nintendo DS Lite Motherboard Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Nintendo DS Lite Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Use the flat edge of a spudger to pry the microphone connector straight up from its socket on the motherboard.
  2. Nintendo DS Lite Motherboard Replacement: 步骤 2 中的图像 1,3 Nintendo DS Lite Motherboard Replacement: 步骤 2 中的图像 2,3 Nintendo DS Lite Motherboard Replacement: 步骤 2 中的图像 3,3
    • In the following steps you must pull the antenna cable between the DS Lite game cartridge reader and motherboard. Pull slowly and stop when you feel resistance to avoid damaging the cable or motherboard.
    • Position the antenna cable with its connector facing up and away from the motherboard using a spudger to hold it down lightly in the gap between chips on the motherboard.
    • Slowly and carefully pull the antenna cable until the cable connector is under the DS Lite game cartridge reader.
    • Continue pulling the cable until the cable connector comes out from under the game cartridge reader on the right side.
    • When reassembling and attempting to feed the antenna cable back under the game cartridge reader, the cable may kink or become difficult to feed through. If so, try feeding a piece of thread through first; then, tie the thread to one end of the cable connector and pull it through, guiding it past any obstructions.
  3. Nintendo DS Lite Motherboard Replacement: 步骤 3 中的图像 1,2 Nintendo DS Lite Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use your fingernail or the edge of a spudger to carefully flip up the touchscreen ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
  4. Nintendo DS Lite Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the two 3.4 mm Phillips screws securing the motherboard to the upper case.
  5. Nintendo DS Lite Motherboard Replacement: 步骤 5 中的图像 1,1
    • Open the display enough to use your finger to push the front edge of the motherboard up and away from the upper case.
    • Do not try to remove the motherboard, as it is still connected to the upper display via the upper LCD ribbon cable.
  6. Nintendo DS Lite Motherboard Replacement: 步骤 6 中的图像 1,2 Nintendo DS Lite Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap.
    • Pull the motherboard away from the DS Lite to separate the upper LCD ribbon cable from its socket on the motherboard.
    • Remove the motherboard from the DS Lite.
    • Now you may open the retaining flap for the lower LCD screen in the same way and separate the lower LCD screen from the motherboard.
结论
2等其他人完成本指南。
Matthew Newsom
于01/05/10注册
39,496 声望
创作了67篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,490
