跳转到主内容
Nintendo DS Lite Lower Case Replacement
你所需要的
  1. Nintendo DS Lite Lower Case Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo DS Lite Lower Case Replacement, Battery: 步骤 1 中的图像 2,2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Nintendo DS Lite Lower Case Replacement: 步骤 2 中的图像 1,1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
  3. Nintendo DS Lite Lower Case Replacement, Lower Case: 步骤 3 中的图像 1,2 Nintendo DS Lite Lower Case Replacement, Lower Case: 步骤 3 中的图像 2,2
    • Use the tip of a spudger to pry both rubber feet off the DS Lite.
  4. Nintendo DS Lite Lower Case Replacement: 步骤 4 中的图像 1,1
    • Remove the following screws securing the lower case to the body of the DS Lite:
    • Two 4.3 mm gold Phillips screws
    • One 3.9 mm black Tri-Wing screw
    • One 3.3 mm silver Phillips screw
    • Three 5.5 mm silver Tri-Wing screws
  5. Nintendo DS Lite Lower Case Replacement: 步骤 5 中的图像 1,3 Nintendo DS Lite Lower Case Replacement: 步骤 5 中的图像 2,3 Nintendo DS Lite Lower Case Replacement: 步骤 5 中的图像 3,3
    • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
    • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
    • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
  6. Nintendo DS Lite Lower Case Replacement: 步骤 6 中的图像 1,1
    • Lift the lower case away from the rest of the DS Lite.
    • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
结论
33等其他人完成本指南。
Matthew Newsom
于01/05/10注册
39,524 声望
创作了67篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 45
过去 30 天: 208
总计 27,345
