简介
换掉你的Nintendo DS Lite的背盖,让它看起来跟刚从店里买来一样崭新!
你所需要的
卸下DS Lite背盖上以下几颗螺丝:
2颗金黄色4.3毫米十字形螺丝
1颗黑色3.9毫米Y字形螺丝
1颗银色3.3毫米十字形螺丝
3颗银色5.5毫米Y字形螺丝
I cannot remove the tri-wing screws.
Zach Smith - 回复
Same to me. I tried opening the case by force. Broke several parts of the motherboard…
Leon -
I can't remove the final tri wing screw in the battery section and it looks like I grinded the screw out too much for any screwdriver to work.Is there anything I can do?
From what I know, the only solution is to drill the screw out with a very small-headed drill :/
Polaris -
将撬棒的边缘插入DS Lite顶部右端前盖与背盖之间的缝隙中。
小心翼翼的将撬棒沿着DS Lite的右边缘移动,制造出一条间隙。
持续沿着DS Lite的下端移动撬棒,直到背盖大体上与前盖分离。
Don’t forget to remove the GBA cartridge placeholder before removing the backside
You forgot to mention to remove the battery compartment Phillips screw.
将背盖从DS Lite本体上掀开来。
When you reassemble, make sure that you have the volume and power buttons in place, and make sure they are in the right position to line up with the switches on the motherboard. If they are not aligned, you risk snapping off the tiny switches on the motherboard (in which case, you are in for some soldering work).
I should have read the comments first - broke off the power switch because I didn't know about aligning it. No way I can do soldering, guess it's for the dustbin :-(
Emma -
Whoops, remembered the power button but forgot the volume slider.
I'll do it later.
There is no way that the fact you have to line up the volume and power switch toggles upon reassembly is not in this guide. I just carefully followed this guide to replace the shoulder buttons but ruined my DS lite because I didn’t read these (practically hidden comments due to the design of the website) comments and broke the power switch. Thankfully there are 150 million DS I can buy second hand but “repeat the steps backwards” wasn’t sufficient in this repair. And that’s what this website is for.
Ryan -
按照指南的倒序重新组装好你的设备。
按照指南的倒序重新组装好你的设备。
33等其他人完成本指南。
由衷感谢以下译者:
75%
Cinmu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
A Phillips #000 (PH000) seems to give a more secure fit (no slipping) than the stated Phillips #00.
Ritchie - 回复
This will be good for mods
Matthew Bevins - 回复
I'm having a problem getting the screw to unscrew. I have the right Phillips ( it was included with all the stuff I got this) Any tips. it doesn't look like the screw is spinning but i haven't played my Nintendo DS Lite for 3 years.
whittlegirls - 回复
bonjour j’ai une petite question pour vous fais trés longtemps que j’ai pas utiliser mon nintendo ds lite et quand je le branche il allume 1 fois orange après il s’enteint même s’il est brancher ça veux tu dire qu’il faut que je change de batterie ? Merci
Marie-Julie Richer - 回复
Soit un changement de batterie, soit la carte-mère a peut-être un court-circuit :/
Polaris -
