简介
Has your DS Lite battery stopped providing the game time you deserve? Replace the battery to free yourself from the wall charger.
你所需要的
Unscrew the Phillips screw securing the battery cover to the lower case.
Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
46等其他人完成本指南。
5条评论
Can you describe the type of screw and captive washer ?
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
A Phillips #000 (PH000) seems to give a more secure fit (no slipping) than the stated Phillips #00.
Ritchie - 回复
This will be good for mods
Matthew Bevins - 回复
I'm having a problem getting the screw to unscrew. I have the right Phillips ( it was included with all the stuff I got this) Any tips. it doesn't look like the screw is spinning but i haven't played my Nintendo DS Lite for 3 years.
whittlegirls - 回复
bonjour j’ai une petite question pour vous fais trés longtemps que j’ai pas utiliser mon nintendo ds lite et quand je le branche il allume 1 fois orange après il s’enteint même s’il est brancher ça veux tu dire qu’il faut que je change de batterie ? Merci
Marie-Julie Richer - 回复
Soit un changement de batterie, soit la carte-mère a peut-être un court-circuit :/
Polaris -
