跳转到主内容
Nintendo DS Lite Battery Replacement
你所需要的
  1. Nintendo DS Lite Battery Replacement, Battery: 步骤 1 中的图像 1,2 Nintendo DS Lite Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Nintendo DS Lite Battery Replacement: 步骤 2 中的图像 1,1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
结论
46等其他人完成本指南。
Matthew Newsom
于01/05/10注册
39,524 声望
创作了67篇指南
5条评论
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - 回复
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - 回复
Thanks but will a dsi battery work
Zach - 回复
My battery cover won’t come off.
Jake - 回复
Flip the console upside down and it will but don’t pull it will break hold it close to the console then slide it back
dead -
添加评论
浏览统计数据:
过去 24 小时: 25
过去 7 天: 192
过去 30 天: 878
总计 53,582
