跳转到主内容
加入维修社区 - 创建账户
Nintendo DS Lite电池更换指南
你所需要的
  1. Nintendo DS Lite电池更换指南, 电池: 步骤 1 中的图像 1,2 Nintendo DS Lite电池更换指南, 电池: 步骤 1 中的图像 2,2
    • 卸下电池盖下方固定着的十字形螺丝。
    • 螺丝会留在电池盖上。
    • 用撬棒或指甲撬起电池盖,并从盖子的底部掀起来。
  2. Nintendo DS Lite电池更换指南: 步骤 2 中的图像 1,1
    • 将一根撬棒插入电池边缘与背盖之间的缝隙里,并往上撬以移开电池。
    • 将电池从DS Lite上取下来。
结论
按照指南的倒序重新组装好你的设备。
50等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Cinmu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Matthew Newsom
于01/05/10注册
42,214 声望
创作了67篇指南
6指南评论
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - 回复 分享
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - 回复 分享
Thanks but will a dsi battery work
Zach - 回复 分享
While a very late reply, someone else may find this useful.
In short, no. Not at all. The DS Lite Battery I own (Original) Is listed as
USG-003
3.7v
1000 mAH
3.7 Wh
Where as the DSi battery I own (Again, an original straight from my console) is listed as:
TWL-003
3.7v
840 mAH
3.1 Wh
While the same voltage and a slight difference in capacity, the DSi Battery is slightly longer and slimmer in width to the DS/DS Lite Battery and you will need to find a battery suited for the DS/DS Lite you're using. Many places will sell these batteries but do your research as not all of these are created equal.
kaelowynlee - 分享
My battery cover won’t come off.
Jake - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 41
过去 7 天: 211
过去 30 天: 938
总计 71,445
