简介
更换你的Nintendo DS Lite的扳机键并回到游戏中!
你所需要的
将两个扳机键从DS Lite中提起来。
Anything after step 7 is unnecessary if having to replace the left or right trigger button(s).
Nate River - 回复
按照指南的倒序重新组装好你的设备。
按照指南的倒序重新组装好你的设备。
34等其他人完成本指南。
由衷感谢以下译者:
100%
Cinmu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
6条评论
Thank you this helped a lot I can finnaly play Zelda and Mario Cart now
Hi! I am attempting a trigger repair, but it seems the console was opened and worked on before I got my hands on it, and the switch for the trigger snapped off the board. I taped it to the board to test, and it still works. Is my best bet soldering the switch back to the motherboard? Or could I get away with superglue? (I've never soldered before, and this looks delicate)
I would definitely solder it, usually, these triggers are the ones that get the most stress and dirt around them so superglue might not last that much. If you have a problem with the trigger still. You might want to check the video I uploaded, it is in Spanish, though. https://youtu.be/7GRzZh9ZdNM
I dont get how removing them is supposed to fix it. it says you need no parts. someone explain
This gives you access to them and now you can clean them. There's some YouTube videos showing how, maybe some cleaning alcohol on a q-tip does the trick, or you have to take apart the buttons front and clean the contacts.
