本指南有最近更改,您可查看未经巡查的最新版本。
简介
After removing the circuit board, the bottom LCD screen can easily be removed from the Nintendo DS.
你所需要的
Remove the cartridge from the console.
Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
Remove the battery door.
Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
Peel off the back foam on the bottom touch screen to expose the ribbon cable.
Gently lift the screen out of the base.
22等其他人完成本指南。
2条评论
I like it but add a step 12 maybe, to see how to put in a new screen.
Why was this unfinished guide published?
Or was it just mistitled?
"How to 'almost' remove the lower screen"
