跳转到主内容
Nintendo DS Bottom LCD Screen Replacement
你所需要的
  1. Nintendo DS Bottom LCD Screen Replacement, Battery: 步骤 1 中的图像 1,3 Nintendo DS Bottom LCD Screen Replacement, Battery: 步骤 1 中的图像 2,3 Nintendo DS Bottom LCD Screen Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Bottom LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Bottom LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Bottom LCD Screen Replacement, Back Panel: 步骤 4 中的图像 1,1
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
  5. Nintendo DS Bottom LCD Screen Replacement: 步骤 5 中的图像 1,3 Nintendo DS Bottom LCD Screen Replacement: 步骤 5 中的图像 2,3 Nintendo DS Bottom LCD Screen Replacement: 步骤 5 中的图像 3,3
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
    If some of your screws spin free but can’t be removed, it maybe that the screw posts have separated from the shell.
    This makes separating the back panel more difficult, but it will still work.
    The plastic used for the original silver nds may be the most prone to the UV damage that causes the plastic to become brittle.
    Del Riordan - 回复
  6. Nintendo DS Bottom LCD Screen Replacement, Motherboard replacement.: 步骤 6 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
  7. Nintendo DS Bottom LCD Screen Replacement: 步骤 7 中的图像 1,3 Nintendo DS Bottom LCD Screen Replacement: 步骤 7 中的图像 2,3 Nintendo DS Bottom LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Unlock the two large ribbon cables by moving the black clip up.
    • Carefully pull the ribbon cables down and out with your fingers.
    • Do not use pliers to pull the cables, as they can be damaged easily.
    Benutze für die nächsten Schritte besser einen Spudger und keine Pinzette,
    sonst läufst du Gefahr eines der Kabel oder die Platine selbst zu beschädigen.
    Better use a Spudger, not a Tweezer for the next Steps.
    That minimize the risk to demolish one of the wires or the mainboard himself.
    Christian - 回复
    That’s what i did but it didn’t work
    TrequanBlake - 回复
  8. Nintendo DS Bottom LCD Screen Replacement: 步骤 8 中的图像 1,2 Nintendo DS Bottom LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
    • Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • It may be useful to use tweezers to remove the small ribbon cables.
    • Be careful not to damage the delicate ribbon cables.
    Does anyone know where I can get a new connector for the P6 connector? I can only find them for the ds lite
    Matthew Leto - 回复
    "Slide the locks for the small ribbon cables down to the side, and remove the cables." Could mention that you are pushing them from the right to the left/towards where the cables are coming from. To the side sounds like towards the right edge
    M Beck - 回复
  9. Nintendo DS Bottom LCD Screen Replacement: 步骤 9 中的图像 1,2 Nintendo DS Bottom LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Locate the Wifi antenna pigtail connector.
    • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
  10. Nintendo DS Bottom LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Feed the ribbon cables through the opening on the board.
    • Pull up and remove the circuit board, and set it aside.
  11. Nintendo DS Bottom LCD Screen Replacement, Bottom LCD Screen: 步骤 11 中的图像 1,2 Nintendo DS Bottom LCD Screen Replacement, Bottom LCD Screen: 步骤 11 中的图像 2,2
    • Peel off the black cushion foam on the bottom touch screen to expose the ribbon cable.
    • Gently lift the screen out of the base.
结论
22等其他人完成本指南。
dnguye26
于10/28/09注册
694 声望
创作了4篇指南
团队
Cal Poly, Team 18-3, Maness Fall 2009 Cal Poly, Team 18-3, Maness Fall 2009 的会员
CPSU-MANESS-F09S18G3
4 名成员
创作了28篇指南
2条评论
I like it but add a step 12 maybe, to see how to put in a new screen.
Zackary Benton - 回复
Why was this unfinished guide published?
Or was it just mistitled?
"How to 'almost' remove the lower screen"
mgoerlich1990 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 57
过去 30 天: 285
总计 41,886
