跳转到主内容
Nintendo DS Bottom LCD Screen Replacement
你所需要的
  1. Nintendo DS Bottom LCD Screen Replacement, Battery: 步骤 1 中的图像 1,3 Nintendo DS Bottom LCD Screen Replacement, Battery: 步骤 1 中的图像 2,3 Nintendo DS Bottom LCD Screen Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Bottom LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Bottom LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Bottom LCD Screen Replacement, Back Panel: 步骤 4 中的图像 1,1
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
  5. Nintendo DS Bottom LCD Screen Replacement: 步骤 5 中的图像 1,3 Nintendo DS Bottom LCD Screen Replacement: 步骤 5 中的图像 2,3 Nintendo DS Bottom LCD Screen Replacement: 步骤 5 中的图像 3,3
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
  6. Nintendo DS Bottom LCD Screen Replacement, Motherboard replacement.: 步骤 6 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
  7. Nintendo DS Bottom LCD Screen Replacement: 步骤 7 中的图像 1,3 Nintendo DS Bottom LCD Screen Replacement: 步骤 7 中的图像 2,3 Nintendo DS Bottom LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Unlock the two large ribbon cables by moving the black clip up.
    • Carefully pull the ribbon cables down and out with your fingers.
    • Do not use pliers to pull the cables, as they can be damaged easily.
  8. Nintendo DS Bottom LCD Screen Replacement: 步骤 8 中的图像 1,2 Nintendo DS Bottom LCD Screen Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
    • Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • It may be useful to use tweezers to remove the small ribbon cables.
    • Be careful not to damage the delicate ribbon cables.
  9. Nintendo DS Bottom LCD Screen Replacement: 步骤 9 中的图像 1,2 Nintendo DS Bottom LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Locate the Wifi antenna pigtail connector.
    • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
  10. Nintendo DS Bottom LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Feed the ribbon cables through the opening on the board.
    • Pull up and remove the circuit board, and set it aside.
  11. Nintendo DS Bottom LCD Screen Replacement, Bottom LCD Screen: 步骤 11 中的图像 1,2 Nintendo DS Bottom LCD Screen Replacement, Bottom LCD Screen: 步骤 11 中的图像 2,2
    • Peel off the black cushion foam on the bottom touch screen to expose the ribbon cable.
    • Gently lift the screen out of the base.
结论
23等其他人完成本指南。
dnguye26
于10/28/09注册
740 声望
创作了4篇指南
团队
Cal Poly, Team 18-3, Maness Fall 2009 Cal Poly, Team 18-3, Maness Fall 2009 的会员
CPSU-MANESS-F09S18G3
4 名成员
创作了31篇指南
2指南评论
I like it but add a step 12 maybe, to see how to put in a new screen.
Zackary Benton - 回复
Why was this unfinished guide published?
Or was it just mistitled?
"How to 'almost' remove the lower screen"
mgoerlich1990 - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 114
过去 30 天: 430
总计 48,663
