简介
Removing the back panel is simple, provided you have the correct screwdriver. Nintendo uses a special Tri-point bit for the case, be sure you have one of these before disassembling!
你所需要的
Remove the cartridge from the console.
Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
Remove the battery door.
20等其他人完成本指南。
