跳转到主内容
Nintendo 64 Power Supply Power Cable Replacement
你所需要的
  1. Nintendo 64 Power Supply Power Cable Replacement, Power Cable: 步骤 1 中的图像 1,2 Nintendo 64 Power Supply Power Cable Replacement, Power Cable: 步骤 1 中的图像 2,2
    • Unscrew the 2 security screws on the corners of the case using a 4.5mm security bit driver.
  2. Nintendo 64 Power Supply Power Cable Replacement: 步骤 2 中的图像 1,2 Nintendo 64 Power Supply Power Cable Replacement: 步骤 2 中的图像 2,2
    • Remove the cover by gently prying from the side with the screws.
    • There are two clips that will let loose on the opposite side as you pry.
    • This will expose the circuit board needed for the repair.
  3. Nintendo 64 Power Supply Power Cable Replacement: 步骤 3 中的图像 1,1
    • Remove the circuit board from the other half of the plastic case by pulling it straight out
    • There may be some adhesive holding it on to the plastic
  4. Nintendo 64 Power Supply Power Cable Replacement: 步骤 4 中的图像 1,2 Nintendo 64 Power Supply Power Cable Replacement: 步骤 4 中的图像 2,2
    • Remove the original power leads by melting the solder using a soldering gun.
    • You will need to pull the wire from the backside but use caution to not touch any metallic parts as they will be hot.
    • If you do not know how to solder, read this Soldering Skills guide on ifixit.
  5. Nintendo 64 Power Supply Power Cable Replacement: 步骤 5 中的图像 1,3 Nintendo 64 Power Supply Power Cable Replacement: 步骤 5 中的图像 2,3 Nintendo 64 Power Supply Power Cable Replacement: 步骤 5 中的图像 3,3
    • Clear the boot by pulling the copper wires out with pliers.
    • This will leave the wire sheathing which can then be cut flush with sharp knife.
    • Tip: Sand cut the end with fine grit sandpaper if desired.
  6. Nintendo 64 Power Supply Power Cable Replacement: 步骤 6 中的图像 1,2 Nintendo 64 Power Supply Power Cable Replacement: 步骤 6 中的图像 2,2
    • Use the drill to drill out the wire sheathing.
    • Drill each hole twice.
    • First, use a 5/64th drill bit. Then, use a larger 1/8th drill bit to finish.
    • The holes should be clean and free of debris once complete.
  7. Nintendo 64 Power Supply Power Cable Replacement: 步骤 7 中的图像 1,3 Nintendo 64 Power Supply Power Cable Replacement: 步骤 7 中的图像 2,3 Nintendo 64 Power Supply Power Cable Replacement: 步骤 7 中的图像 3,3
    • Feed the new cable through the boot .
    • Glue it in place by applying glue to the wire (close to the desired location of the boot) and sliding the boot into place.
    • Be sure the exposed wire length is close to the original.
  8. Nintendo 64 Power Supply Power Cable Replacement: 步骤 8 中的图像 1,2 Nintendo 64 Power Supply Power Cable Replacement: 步骤 8 中的图像 2,2
    • Align the wires with their original positions on the circuit board.
    • Looking at the component side of the board, the hot side is marked with an L for load and the neutral is marked with an N.
    • The neutral wire goes here, the hole closer to the center of the circuit board.
    • The hot wire goes here, closer to the outside.
    • The neutral wire can be identified by the wider prong on the plug end of the cord.
  9. Nintendo 64 Power Supply Power Cable Replacement: 步骤 9 中的图像 1,2 Nintendo 64 Power Supply Power Cable Replacement: 步骤 9 中的图像 2,2
    • Solder the new wires onto the circuit board.
  10. Nintendo 64 Power Supply Power Cable Replacement: 步骤 10 中的图像 1,2 Nintendo 64 Power Supply Power Cable Replacement: 步骤 10 中的图像 2,2
    • Use a flexible glue to put on the original adhesive.
    • Insert the board, aligning the boot with the slot.
结论
To reassemble your device, follow steps 1-3 in reverse order.
Brandon Clausen
于06/23/23注册
181 声望
撰写一个指南
团队
ENGL 3603 Group 4 ENGL 3603 Group 4 的会员
Local Repair Groups
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 12
过去 30 天: 83
总计 721
