跳转到主内容
Nintendo 64 Motherboard Replacement
你所需要的
  1. Nintendo 64 Motherboard Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Motherboard Replacement: 步骤 2 中的图像 1,1
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the two front feet of the N64.
  5. Nintendo 64 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Motherboard Replacement, Metal Plate: 步骤 6 中的图像 1,2 Nintendo 64 Motherboard Replacement, Metal Plate: 步骤 6 中的图像 2,2
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
    I’m not entirely certain if it's a common difference, but my nintendo 64 doesn’t have fourteen screws, but rather, 8 screws, and instead of 3 heat sinks, it only has the one separate heat sink on the chip close to the memory expansion pack. additionally, aside from the 6 screws closest to the expansion pack, the two other screws are held on by nuts under the metal piece.
    Avery Duncan - 回复
  7. Nintendo 64 Motherboard Replacement: 步骤 7 中的图像 1,2 Nintendo 64 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Motherboard Replacement: 步骤 11 中的图像 1,2 Nintendo 64 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
    I have noticed this is not in Australian Pal versions of the N64.
    at First i thought i was missing a bit on my N64 and now have looked a second one and its also not there.
    Darren Welch - 回复
  12. Nintendo 64 Motherboard Replacement: 步骤 12 中的图像 1,2 Nintendo 64 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Motherboard Replacement: 步骤 13 中的图像 1,2 Nintendo 64 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
    The two screws next to the cartridge slot are longer
    Michael - 回复
  14. Nintendo 64 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Lift off and remove the metal plate as indicated in the example.
  15. Nintendo 64 Motherboard Replacement, Motherboard: 步骤 15 中的图像 1,1
    • Remove the four screws indicated using the #1 Phillips screwdriver.
    I found the #2PH to work a bit better here
    Rand Avary - 回复
  16. Nintendo 64 Motherboard Replacement, Motherboard removal: 步骤 16 中的图像 1,1
    • Lift up and remove the motherboard.
结论
36等其他人完成本指南。
tonymag28
于10/28/09注册
2,154 声望
创作了3篇指南
团队
Cal Poly, Team 5-4, Regan Fall 2009 Cal Poly, Team 5-4, Regan Fall 2009 的会员
CPSU-REGAN-F09S5G4
7 名成员
创作了15篇指南
3条评论
4.2mm doesn't seem right. When I looked to purchase all I saw was 4.5mm and now that I have one in my hand it seems to fit very precisely on the screws on my N64.
negroslim - 回复
i got the second comment :whyy:
Sqwerks - 回复
What are the symptoms of a bad motherboard?
Jon - 回复
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 120
过去 30 天: 528
总计 63,652
