跳转到主内容
加入维修社区 - 创建账户
Nintendo 64 Metal Plate Replacement
你所需要的
  1. Nintendo 64 Metal Plate Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Metal Plate Replacement: 步骤 2 中的图像 1,1
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Metal Plate Replacement: 步骤 3 中的图像 1,1
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Metal Plate Replacement: 步骤 4 中的图像 1,1
    • Remove the two front feet of the N64.
  5. Nintendo 64 Metal Plate Replacement: 步骤 5 中的图像 1,1
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Metal Plate Replacement, Metal Plate: 步骤 6 中的图像 1,2 Nintendo 64 Metal Plate Replacement, Metal Plate: 步骤 6 中的图像 2,2
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  7. Nintendo 64 Metal Plate Replacement: 步骤 7 中的图像 1,2 Nintendo 64 Metal Plate Replacement: 步骤 7 中的图像 2,2
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Metal Plate Replacement: 步骤 8 中的图像 1,1
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Metal Plate Replacement: 步骤 9 中的图像 1,1
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Metal Plate Replacement: 步骤 10 中的图像 1,1
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Metal Plate Replacement: 步骤 11 中的图像 1,2 Nintendo 64 Metal Plate Replacement: 步骤 11 中的图像 2,2
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Nintendo 64 Metal Plate Replacement: 步骤 12 中的图像 1,2 Nintendo 64 Metal Plate Replacement: 步骤 12 中的图像 2,2
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Metal Plate Replacement: 步骤 13 中的图像 1,2 Nintendo 64 Metal Plate Replacement: 步骤 13 中的图像 2,2
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  14. Nintendo 64 Metal Plate Replacement: 步骤 14 中的图像 1,1
    • Lift off and remove the metal plate as indicated in the example.
结论
6等其他人完成本指南。
LisaF818
于11/29/09注册
158 声望
撰写一个指南
团队
Cal Poly, Team 5-4, Regan Fall 2009 Cal Poly, Team 5-4, Regan Fall 2009 的会员
CPSU-REGAN-F09S5G4
7 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 71
总计 12,637
