本指南有最近更改,您可查看未经巡查的最新版本。
简介
This fix is necessary for the owners of N64 controllers when the joystick becomes too loose over time. If the joystick of a controller is loose, game play becomes difficult. Conditions for this fix include: a flat surface, plenty of light, and a method for keeping track of individual components of the controller. Practice caution when using the knife in this fix.
你所需要的
Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
Remove the back panel from the controller.
The fix is now complete. Move the joystick to test the stiffness. If the joystick is still very loose, you may need to add more epoxy. If the joystick is too stiff, you may need to remove excess epoxy.
13等其他人完成本指南。
7条评论
N64 Joystick Permanent Fix & Refurbish New Parts Cheap
Sadly, it is out of stock too frequently. I’d prefer fixing rather than replacing.
What is the epoxy substance called exactly? I tried searching online but results all come back for JB-Weld coldweld bonding products.
chrisdeliz - 回复
It took me a while too to find what they're using. I'm pretty sure it's Epoxy Putty, it's used to patch and seal holes.
JB-Weld does seem to sell most of what's available to buy, maybe their PlasticWeld one would be most appropriate.
