跳转到主内容
Nintendo 64 Controller D-Pad Replacement
你所需要的
  1. Nintendo 64 Controller D-Pad Replacement, Controller D-Pad Replacement: 步骤 1 中的图像 1,3 Nintendo 64 Controller D-Pad Replacement, Controller D-Pad Replacement: 步骤 1 中的图像 2,3 Nintendo 64 Controller D-Pad Replacement, Controller D-Pad Replacement: 步骤 1 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the seven 10 mm screws from the body.
    • Remove the two 6 mm Phillips #0 screws from the expansion slot.
    • Separate the back cover from the front and set it aside.
  2. Nintendo 64 Controller D-Pad Replacement: 步骤 2 中的图像 1,2 Nintendo 64 Controller D-Pad Replacement: 步骤 2 中的图像 2,2
    • Remove the left and right shoulder triggers by sliding them straight up.
    • Gently unhook the cable that is looped around two cable clamps by nudging it up and out.
  3. Nintendo 64 Controller D-Pad Replacement: 步骤 3 中的图像 1,3 Nintendo 64 Controller D-Pad Replacement: 步骤 3 中的图像 2,3 Nintendo 64 Controller D-Pad Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the three silver 6 mm screws holding the joystick assembly in place.
    • Gently lift the motherboard and joystick assembly out of the controller.
    • In order to avoid damage to the board, lift it by the edges.
  4. Nintendo 64 Controller D-Pad Replacement: 步骤 4 中的图像 1,3 Nintendo 64 Controller D-Pad Replacement: 步骤 4 中的图像 2,3 Nintendo 64 Controller D-Pad Replacement: 步骤 4 中的图像 3,3
    • Slide the rubber pad off that covers the back of the D-pad.
    • Remove the broken D-pad from its socket.
  5. Nintendo 64 Controller D-Pad Replacement: 步骤 5 中的图像 1,3 Nintendo 64 Controller D-Pad Replacement: 步骤 5 中的图像 2,3 Nintendo 64 Controller D-Pad Replacement: 步骤 5 中的图像 3,3
    • Insert the replacement D-pad into the socket.
    • Stretch the rubber backing onto the plastic pieces and slide it down over the D-pad.
    • Carefully reinsert the circuit board into the controller housing.
    • Insert the joystick into its opening.
  6. Nintendo 64 Controller D-Pad Replacement: 步骤 6 中的图像 1,3 Nintendo 64 Controller D-Pad Replacement: 步骤 6 中的图像 2,3 Nintendo 64 Controller D-Pad Replacement: 步骤 6 中的图像 3,3
    • Carefully secure the cord around the cable clamps.
    • Be sure to apply enough pressure so it sits below or flush to the edge to avoid problems putting the front and back case together.
    • Re-insert the shoulder triggers into place.
    • The L trigger will go on the right and the R trigger on the left.
    • Use a Phillips #0 screwdriver to secure the screws to the joystick assembly.
  7. Nintendo 64 Controller D-Pad Replacement: 步骤 7 中的图像 1,2 Nintendo 64 Controller D-Pad Replacement: 步骤 7 中的图像 2,2
    • Snap the back cover into place.
    • Use a Phillips #0 screwdriver to replace the screws on the back cover.
结论
Happy gaming!
另外一个人完成了本指南。
Jamie Durman
于07/01/23注册
169 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 67
总计 977
