当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the expansion pack cover by pushing in the tab and pulling out.
If your system uses a jumper pack, the same procedure applies to remove it.
A small spoon can be used in place of a spudger.
Lever the expansion pack out using a metal spudger.
Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
Remove the two front feet of the N64.
Rotate to top side up and lift off top cover.
Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
Remove the metal plate indicated in the example by sliding it back and then lifting it up.
Remove the two screws indicated in the example using the smaller Phillips screwdriver.
Remove the screw to the right of the LED light using the larger Phillips screwdriver.
Remove the small metal bracket from the back of the expansion pack slot.
Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
Remove the small metal bracket behind the expansion slot using the spudger.
Remove the seven screws indicated in the example using the larger Phillips screwdriver.
Lift off and remove the metal plate as indicated in the example.
Remove the four screws indicated using the #1 Phillips screwdriver.
Lift up and remove the motherboard.
Remove everything from the bottom cover.
取消:我没有完成这个指南。
23等其他人完成本指南。
与4其他贡献者
于10/28/09注册
2,159 声望
创作了3篇指南
徽章: 14
+ 11更多徽章
CPSU-REGAN-F09S5G4
7 名成员
创作了15篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 52
过去 30 天: 202
总计 40,324
