跳转到主内容
Nintendo 64 Rumble Pak Battery Replacement
你所需要的
  1. Nintendo 64  Rumble Pak Battery Replacement, Rumble Pak Battery: 步骤 1 中的图像 1,1
    • Remove the Rumble Pak from the controller by pressing the release button and pulling the Rumble Pak out.
  2. Nintendo 64  Rumble Pak Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the battery cover from the Rumble Pak by pressing the tab and pulling the cover up.
  3. Nintendo 64  Rumble Pak Battery Replacement: 步骤 3 中的图像 1,1
    • Press each battery toward the spring, then pull toward you to remove the batteries from the Rumble Pak.
    • When inserting the new batteries, make sure the positive (+) end of the battery touches the flat piece, and the negative (-) end touches the spring.
  4. Nintendo 64  Rumble Pak Battery Replacement: 步骤 4 中的图像 1,3 Nintendo 64  Rumble Pak Battery Replacement: 步骤 4 中的图像 2,3 Nintendo 64  Rumble Pak Battery Replacement: 步骤 4 中的图像 3,3
    • Check for corrosion around the springs and the flat plate where the batteries touch.
    • Do not touch the corrosion. It may be battery acid.
    • Use a flat head screwdriver to chisel away the corrosion, and use a Q-tip to wipe it clean.
    • Do not use water to wet the Q-tip, as water can damage the Rumble Pak.
结论
Carly Bowen
于07/20/15注册
304 声望
撰写一个指南
团队
Texas Tech, Team 3-6, Rauch SU 2015 Texas Tech, Team 3-6, Rauch SU 2015 的会员
TTU-RAUCH-SU15S3G6
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 38
总计 4,025
