跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide to replace the Power Button will take you through the steps of disassembling the Nintendo 3DS past the motherboard in order to access the Power Button.
  1. Loosen the two 4.2 mm-length screws located at the top of the back cover. The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
    • Loosen the two 4.2 mm-length screws located at the top of the back cover.
    • The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
  2. Hold the device so that the cover is facing up. Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Hold the device so that the cover is facing up.
    • Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Hold the edge of the cover to ensure it does not reattach.
    • Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
    • Take off the cover of the device and set aside.
  3. Insert the plastic opening tool into the opening located on the right side of the battery. Pry off the battery from the lower casing. Lift the battery out of the case and set aside.
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry off the battery from the lower casing.
    • Lift the battery out of the case and set aside.
  4. Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment. Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
    • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
  5. Remove the six 6.2 mm screws using a Phillips #00 screwdriver Remove the six 6.2 mm screws using a Phillips #00 screwdriver
    • Remove the six 6.2 mm screws using a Phillips #00 screwdriver
  6. Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #00 screwdriver.
    • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #00 screwdriver.
  7. Make sure the SD card has been removed. With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter. Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables. Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
    • Make sure the SD card has been removed. With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
    • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
  8. Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool. Completely remove the lower case from the rest of the device and set aside. Completely remove the lower case from the rest of the device and set aside.
    • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
    • Completely remove the lower case from the rest of the device and set aside.
  9. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  10. Position the device such that the game cartridge slot is located at the top. Locate the circle pad on the right side of the device.
    • Position the device such that the game cartridge slot is located at the top.
    • Locate the circle pad on the right side of the device.
    • Remove the two 7.5 mm screws on the upper left and the bottom right corners.
  11. Using a plastic opening tool pop off the circle pad joystick. Do not use excessive force with the plastic opening tool. There is a ribbon attaching the circle pad joystick to the motherboard that will remain attached.
    • Using a plastic opening tool pop off the circle pad joystick.
    • Do not use excessive force with the plastic opening tool. There is a ribbon attaching the circle pad joystick to the motherboard that will remain attached.
    • There is a loose washer located in between the circle pad joystick and the circle pad. Use caution and do not lose this piece.
  12. Using the flat head side of the spudger carefully lift up the retaining flap that attaches the circle pad ribbon to the motherboard. Remove the ribbon and circle pad joystick.
    • Using the flat head side of the spudger carefully lift up the retaining flap that attaches the circle pad ribbon to the motherboard.
    • Remove the ribbon and circle pad joystick.
  13. Position the device such that the game cartridge slot is located at the top. Locate the IR board located on the upper right side of the motherboard.
    • Locate the IR board located on the upper right side of the motherboard.
    • The IR board is installed upside-down in these photos by mistake. Installing it this way will result in your DS failing to start. Note the orientation of your IR board before you remove it, and reinstall it the same way.
    • Remove the IR board with a plastic opening tool by inserting the tool below the IR board and gently prying up.
  14. Using a plastic opening tool, pry off the Wi-Fi board. The Wi-Fi board will still be connected by a wire and it is not necessary to completely remove it for this step. Simply place it out of the way for this step.
    • Using a plastic opening tool, pry off the Wi-Fi board.
    • The Wi-Fi board will still be connected by a wire and it is not necessary to completely remove it for this step. Simply place it out of the way for this step.
  15. Locate the volume switch on the right side of the motherboard next to the circle pad joystick. Using tweezers, carefully remove the volume board from the casing. It will still be attached to the motherboard by a ribbon cable.
    • Locate the volume switch on the right side of the motherboard next to the circle pad joystick.
    • Using tweezers, carefully remove the volume board from the casing. It will still be attached to the motherboard by a ribbon cable.
  16. Using the flat head side of the spudger carefully lift up the flap that attaches the volume board ribbon to the motherboard.
    • Using the flat head side of the spudger carefully lift up the flap that attaches the volume board ribbon to the motherboard.
    • Remove the volume board and set aside.
  17. Remove the black plastic pieces from the lower left and right hand corners with either your fingers or tweezers. You can also remove these pieces easily by carefully lifting up the 3DS and holding it upside-down.   They normally fall right out, but don't lose them!
    • Remove the black plastic pieces from the lower left and right hand corners with either your fingers or tweezers.
    • You can also remove these pieces easily by carefully lifting up the 3DS and holding it upside-down. They normally fall right out, but don't lose them!
  18. Using the flat head side of the spudger carefully lift up the flap that attaches the two smaller ribbons to the motherboard. These flaps are located on the top right and bottom right side of the motherboard. Remove the ribbons from the flap.
    • Using the flat head side of the spudger carefully lift up the flap that attaches the two smaller ribbons to the motherboard.
    • These flaps are located on the top right and bottom right side of the motherboard.
    • Remove the ribbons from the flap.
  19. Using the flat head side of the spudger carefully lift up the flaps that attach the wider ribbons to the motherboard. For the wider ribbons make sure to lift the flaps from the white side. Remove the ribbons from the opened flaps.
    • Using the flat head side of the spudger carefully lift up the flaps that attach the wider ribbons to the motherboard.
    • For the wider ribbons make sure to lift the flaps from the white side.
    • Remove the ribbons from the opened flaps.
  20. Using the flat head side of the spudger carefully lift up the flap that attaches the ribbon to the motherboard. For this flap lift from the black side.
    • Using the flat head side of the spudger carefully lift up the flap that attaches the ribbon to the motherboard.
    • For this flap lift from the black side.
    • Remove the ribbon from the flap.
    • Reassembly: This wide ribbon is the one with the BLACK STRIPE and goes on the upper (visible) side of the motherboard during reassembly.
  21. Remove ten 5.5 mm screws that are located around the face of the motherboard. Remove ten 5.5 mm screws that are located around the face of the motherboard.
    • Remove ten 5.5 mm screws that are located around the face of the motherboard.
  22. The motherboard will still be attached at the top right hand corner so do not completely detach it at this point. Carefully lift the board straight up just enough to clear the two plastic mounts located near the top corners of the cartridge slot.
    • The motherboard will still be attached at the top right hand corner so do not completely detach it at this point.
    • Carefully lift the board straight up just enough to clear the two plastic mounts located near the top corners of the cartridge slot.
    • Gently flip the motherboard over the top side.
  23. Using the flat head side of the spudger carefully lift up the flap that attaches the wider ribbon on the upper right side to the motherboard. Make sure to lift the flap from the white side.
    • Using the flat head side of the spudger carefully lift up the flap that attaches the wider ribbon on the upper right side to the motherboard.
    • Make sure to lift the flap from the white side.
    • Remove the ribbon from the opened flap.
    • Set the motherboard aside.
  24. Using tweezers remove the rubber cap located on the bottom left hand corner. Use the tweezers to pull out the power button. Use the tweezers to pull out the power button.
    • Using tweezers remove the rubber cap located on the bottom left hand corner.
    • Use the tweezers to pull out the power button.
结论
2等其他人完成本指南。
Charlene Donlon
于2014年04月08日注册
8,651 信誉积分
创作了8篇指南
团队
Cal Poly, Team 9-13, Regan Spring 2014 Cal Poly, Team 9-13, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G13
5 名成员
创作了21篇指南
Does anyone have any idea where I can get a spare power button (black plastic part) and the rubber bit?
I've found the rubber bit on ebay but for the life of me I cannot find the plastic part (In the UK at least)
Thanks.
hudster1991 - 回复
添加评论
浏览统计数据:
过去的24小时: 4
过去的7天: 28
过去的30天: 106
总计 12,973
