跳转到主内容
Nintendo 3DS XL Hinge/Midframe Replacement
你所需要的
  1. Nintendo 3DS XL Hinge/Midframe Replacement, Hinge/Midframe: 步骤 1 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement, Hinge/Midframe: 步骤 1 中的图像 2,2
    • Flip the 3DS XL upside down.
  2. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 2 中的图像 1,1
    • Remove the two 4.2 mm screws from the back cover using a Phillips #00 screwdriver.
  3. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 3 中的图像 1,1
    • Use an opening tool to pry the cover loose and lift the back cover.
    • Caution: Make sure to lift the side with the screws up first as to not break hooks on the cover.
  4. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 4 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 4 中的图像 2,2
    • Use an opening tool to remove the battery.
  5. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 5 中的图像 1,1
    • Remove the six 6.2 mm screws from the back cover using a Phillips #00 screwdriver.
    • Remove the single 2.3 mm screw from the back cover using a Phillips #00 screwdriver.
  6. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 6 中的图像 1,3 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 6 中的图像 2,3 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 6 中的图像 3,3
    • Use your hands to carefully remove the back cover at an angle, while keeping it connected to the top edge with caution regarding the ribbons.
  7. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 7 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to carefully detach both of the ribbon cables connected to the back cover.
  8. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 8 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 8 中的图像 2,2
    • Remove the two 7.5 mm screws from the white plate.
    • Use your fingers to lift it off the space carefully.
  9. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 9 中的图像 1,1
    • Use a pair of tweezers to remove the small plastic circle from the opened space.
  10. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 10 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 10 中的图像 2,2
    • Use your fingers to carefully disconnect the small green rectangle.
  11. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 11 中的图像 1,1
    • Remove the ten 3 mm screws from the motherboard.
  12. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 12 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 12 中的图像 2,2
    • On the bottom right corner, remove the small plastic piece using a pair of tweezers.
  13. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 13 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 13 中的图像 2,2
    • On the bottom left corner, remove the small plastic piece using a pair of tweezers.
  14. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 14 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 14 中的图像 2,2
    • With caution yet with slight force, use a pair of tweezers to pull and disconnect the ribbon cable from the latch on the top right corner.
  15. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 15 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 15 中的图像 2,2
    • With caution yet with slight force, use a pair of tweezers to pull and disconnect the second ribbon cable from the latch on the top right corner.
  16. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 16 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 16 中的图像 2,2
    • With caution yet with slight force, use your hands to lift the screen and the green motherboard from the frame.
    • Caution: There is still a ribbon cable connected, so do not suddenly remove what was lifted.
  17. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 17 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 17 中的图像 2,2
    • With caution yet with slight force, use a pair of tweezers to pull and disconnect the ribbon cable at the hinge from the latch.
  18. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 18 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 18 中的图像 2,2
    • Use your fingers to disconnect the green rectangle from the small green cable.
  19. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 19 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 19 中的图像 2,2
    • Flip the 3DS XL right side up and open it.
  20. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 20 中的图像 1,3 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 20 中的图像 2,3 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 20 中的图像 3,3
    • Use a pair of tweezers to remove the small rubber squares from each corner of the front screen.
  21. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 21 中的图像 1,1
    • Remove the four 4.3 mm screws from the top screen using a Phillips #00 screwdriver.
  22. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 22 中的图像 1,3 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 22 中的图像 2,3 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 22 中的图像 3,3
    • Use your hands to remove the top cover by pushing the cover horizontally away from the hinges, as to not break any plastic hooks.
  23. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 23 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 23 中的图像 2,2
    • Flip the 3DS XL upside down and find the top left hinge.
    • In the small opening, use a small opening tool to push the small white plastic piece down towards the other hinge.
    • Caution: A decent amount of force will be needed to push it down, so use a small but sturdy object that can fit in the opening to push it down.
  24. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 24 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 24 中的图像 2,2
    • Use a pair of tweezers to remove the small black plastic piece covering the hinge.
  25. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 25 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 25 中的图像 2,2
    • Use a pair of tweezers to remove the small clear plastic piece from the hinge.
    • At this point you can remove the bottom frame from the left hinge using your hands.
  26. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 26 中的图像 1,3 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 26 中的图像 2,3 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 26 中的图像 3,3
    • At the top right hinge, use your hands to carefully slide the ribbon cables through a small gap next to the hinge to remove them from the bottom frame.
  27. Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 27 中的图像 1,2 Nintendo 3DS XL Hinge/Midframe Replacement: 步骤 27 中的图像 2,2
    • Use your fingers to remove all buttons and rubber covers from the old frame and place them into the new frame.
结论
另外一个人完成了本指南。
FixitKevin
于10/25/23注册
412 声望
撰写一个指南
团队
CSU Los Angeles, Team 4-9, Kershman Fall 2023 CSU Los Angeles, Team 4-9, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S4G9
1 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 40
过去 7 天: 282
过去 30 天: 1,207
总计 3,963
