简介
电池出了问题需要更换?本指南将将指导您为天堂3DS XL更换电池所需的步骤。
你所需要的
要重新组装您的设备,请按照本指南的相反顺序进行操作。
42等其他人完成本指南。
由衷感谢以下译者:
57%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
5条评论
Time estimate: 3 - 9 hours Difficulty: Very difficult ??????
More like 30-90 seconds, and that's if you have to search for a screwdriver.
It should be noted that the bottom three clips on the bottom of the backplate can’t just be snapped in, they need to be slipped in, so when removing the backplate, it should be tiled away from the system and then pulled up from the bottom, and those three clips on the bottom should be the first clips in when you’re putting it back together, sliding them in with the backplate at an angle, and then the rest of the clips just snap in.
Nice tip. Ty.
Just did this. For reasmbly I recommend putting the bottom/lower part of the case on first before you screw it back on.
