跳转到主内容
Nintendo 3DS XL 2015 Circle Pad Replacement
你所需要的
  1. Nintendo 3DS XL 2015 Circle Pad Replacement, Circle Pad: 步骤 1 中的图像 1,1
    • Ensure device is turned off and the stylus and game card are removed.
  2. Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 2 中的图像 1,3 Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 2 中的图像 2,3 Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 2 中的图像 3,3
    • Turn the device so that the back cover is facing you and locate the two screws at the top of the back cover.
    • Using the Phillips #000 screwdriver, loosen the screws on the back cover.
    • The screws do not come out, but may be loosened to allow for the back cover to be removed.
    • Gently pry the tabs on the side of the device with the metal spudger or your thumbnail and lift off the back cover.
  3. Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 3 中的图像 1,2 Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 3 中的图像 2,2
    • Remove the microSD card by pushing it in, the card should automatically pop out.
  4. Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 4 中的图像 1,3 Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 4 中的图像 2,3 Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 4 中的图像 3,3
    • To remove the battery, hold the device with the battery facing up in one hand, with a finger securely gripping the lid of the device, and gently flip the device over to your other hand. The battery should fall into your hand.
  5. Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 5 中的图像 1,3 Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 5 中的图像 2,3 Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 5 中的图像 3,3
    • Remove the two rubber bumpers on the back of the device with a thumb tack.
    • Using the Phillips #00 screwdriver, remove all 8 of the screws holding the bottom cover to the motherboard.
    • Lift off the bottom cover, being sure not to disconnect the two ZIF connectors for the L/R buttons on the back of the device.
  6. Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 6 中的图像 1,2 Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 6 中的图像 2,2
    • Using the Phillips #00 screwdriver, remove the two screws holding the circle pad in place.
    • Be sure to keep these screws separate from the bottom cover screws, the circle pad screws are slightly longer and only compatible with the circle pad.
    • Lift the circle pad out of its place to expose the ZIF connector.
  7. Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 7 中的图像 1,1
    • Using the tip of the spudger, gently lift off the lid of the ZIF connector to release the circle pad cable.
  8. Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 8 中的图像 1,3 Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 8 中的图像 2,3 Nintendo 3DS XL 2015 Circle Pad Replacement: 步骤 8 中的图像 3,3
    • Take the new circle pad assembly and insert the cable back into the open ZIF connector and close it using the spudger.
    • Ensure the internal component of the circle pad is correctly oriented with a small screwdriver or spudger.
    • Gently place the new circle pad back into its place and secure with the screws.
    • We had to try this step a few times before we were able to orient it correctly. Try to make sure that the circle pad does not move the internal assembly once it is inserted.
结论
20等其他人完成本指南。
5条评论
oh my gosh this is the best guide my grand-son and i fixed his sons 3DS he is so happy
Andrew Dahm - 回复
2 of my motherboard screws can’t open with my newly ordered philips 00 screwdriver. the screws insides look like circles rather than crosses.
George - 回复
Thanks for the guide! I needed to replace the internal component of the circle pad as well, as the rubber pad came off mine. @thirtyninester 's comment on Step 8 helped! Thanks to that comment as well!
Justin Alex - 回复
Help! I'm stuck on Step 5. Upper leftmost screw refuses to come out and I can't tell whether I've worn down the screwhead or the screwdriver. Removal advice please. Otherwise my only recourse may be to replace the entire system. Just transfer everything datawise and be done with it. It'd be a shame if I had to admit I spent $90+ on parts & tools for nothing just for it to come to this. And I don't even want to think about how much a new unit will cost on the secondhand market. I'll be lucky to find one at it's original MSRP.
Matthew Conklin - 回复
Hey,
you could try to use a slightly larger screwdriver and see if the screw comes out. Otherwise you have to drill the screw out which is probably still better/cheaper than replacing everything. Hope this helps!
Henrynaja -
添加评论
浏览统计数据:
过去 24 小时: 34
过去 7 天: 196
过去 30 天: 890
总计 29,889
