跳转到主内容
Nintendo 3DS Battery Replacement
你所需要的
  1. Nintendo 3DS Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Battery Replacement: 步骤 2 中的图像 1,2 Nintendo 3DS Battery Replacement: 步骤 2 中的图像 2,2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Battery Replacement, Battery: 步骤 3 中的图像 1,3 Nintendo 3DS Battery Replacement, Battery: 步骤 3 中的图像 2,3 Nintendo 3DS Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
结论
45等其他人完成本指南。
David Hodson
于04/13/10注册
150,493 声望
创作了127篇指南
7条评论
Where do you buy a new battery from for your nintendo 3ds?
Midori Neko - 回复
Amazon or eBay are your friend!
Also Nintendo store sells it
Alberto -
Easy as pie. Thanks for writing this guide!
3DRepairMan - 回复
I want to buy a battery to replace the old one, do you have any stablishment in An Salvador where I can buy it?
wilfredo_montesm - 回复
https://store.nintendo.com/battery-pack-... Here it is for the 3ds and 2ds battery pack from Nintendo.
Nelson Berrios - 回复
添加评论
浏览统计数据:
过去 24 小时: 68
过去 7 天: 513
过去 30 天: 2,239
总计 67,630
