跳转到主内容
Nintendo 3DS 2015 Touchscreen Assembly Replacement
你所需要的
  1. Nintendo 3DS 2015 Touchscreen Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the two 3mm Phillips #0 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 2 中的图像 1,2 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 2 中的图像 2,2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 3 中的图像 1,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 3 中的图像 2,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 Touchscreen Assembly Replacement, SD Card Reader: 步骤 4 中的图像 1,1
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 5 中的图像 1,1
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 6 中的图像 1,2 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 6 中的图像 2,2
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
    Where can I buy a new SD card reader? Cant seem to find any.
    Aldair - 回复
  7. Nintendo 3DS 2015 Touchscreen Assembly Replacement, Lower Case: 步骤 7 中的图像 1,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement, Lower Case: 步骤 7 中的图像 2,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement, Lower Case: 步骤 7 中的图像 3,3
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
  8. Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 8 中的图像 1,2 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 8 中的图像 2,2
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
  9. Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 9 中的图像 1,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 9 中的图像 2,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 9 中的图像 3,3
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
  10. Nintendo 3DS 2015 Touchscreen Assembly Replacement, Circle Pad: 步骤 10 中的图像 1,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement, Circle Pad: 步骤 10 中的图像 2,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement, Circle Pad: 步骤 10 中的图像 3,3
    • Locate the joystick assembly near the top right corner of the motherboard.
    • Remove the two 8mm Phillips #00 screws from the back of the joystick.
    • Use the flat end of the spudger to pry off the joystick pad from its plastic housing.
  11. Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 11 中的图像 1,2 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 11 中的图像 2,2
    • Lift the joystick pad and place it on its back. This will reveal the ribbon cable connected to the joystick pad.
    • Use the flat end of the spudger to pry up the retaining flap for the ribbon cable.
    • Lift the joystick out of the device.
  12. Nintendo 3DS 2015 Touchscreen Assembly Replacement, Gamecard Reader: 步骤 12 中的图像 1,2 Nintendo 3DS 2015 Touchscreen Assembly Replacement, Gamecard Reader: 步骤 12 中的图像 2,2
    • Locate the gamecard reader near the bottom right corner of the motherboard.
    • Unscrew the four 3mm Phillips #00 screws along the edge of the gamecard reader.
    • Lift the black latch on the ZIF connector along the right side of the reader using a plastic opening tool.
  13. Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 13 中的图像 1,2 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 13 中的图像 2,2
    • Pry the ribbon cable from its socket, just left of the joystick, using the flat side of a spudger.
    • Grab the right edge of the gamecard reader and lift it out of the device, watching to make sure the ribbon cables don't snag.
  14. Nintendo 3DS 2015 Touchscreen Assembly Replacement, Motherboard: 步骤 14 中的图像 1,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement, Motherboard: 步骤 14 中的图像 2,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement, Motherboard: 步骤 14 中的图像 3,3
    • Remove the power cable, indicated by the black and red wires, by gently pulling it up and out of the connector.
    • Gently pull the ribbon cables out of the 4 ZIF connectors.
    • Do not lift up on the tabs on these ZIF connectors. Lifting these tabs will break the connectors.
    is this possible to fix these connectors once they are “broken” ?
    Nefeh Aiden - 回复
    Another bump, but I am also wondering if it is possible to fix these ZIF connectors.
    Ilija Manojlovic - 回复
  15. Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 15 中的图像 1,2 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 15 中的图像 2,2
    • Pull up gently on the blue wifi antenna.
    • Pry the retaining tab on the connector behind the infrared receiver and gently pull the ribbon cable from the connector with tweezers.
  16. Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 16 中的图像 1,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 16 中的图像 2,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 16 中的图像 3,3
    • Lift the retaining tab and remove the large ribbon cable on the left side of the motherboard.
    • Lift the retaining tab and remove the large ribbon cable on the top of the motherboard behind the infrared receiver.
    • Lift the retaining tab and remove the large ribbon cable on the top of the motherboard just above the joysitck housing.
  17. Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 17 中的图像 1,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 17 中的图像 2,3 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 17 中的图像 3,3
    • Double check that all motherboard connection on the top of the board have been disconnected.
    • Remove the three, 3mm Phillips #00 screws that secure the motherboard to the device housing.
    • Lift the motherboard genlty by the headphone jack.
    • Remove the two ribbons on the back of the device by lifting the retaining tabs on the ZIF connectors.
    Far right screw was already missing. It appears this occurred in the demonstration unit as well, based on the image for step 12.
    Kyle Dumouchelle - 回复
    it's not missing ^^ it is an error by the writer or the article. this screw is actually matching with one of the outer casing
    Nefeh Aiden -
    Is this motherboard the same as the xl?
    Isak Ahlgren-McCune - 回复
    Wondering this as well. Can’t seem to find a replacement board.
    Joseph -
  18. Nintendo 3DS 2015 Touchscreen Assembly Replacement, Touchscreen Assembly: 步骤 18 中的图像 1,2 Nintendo 3DS 2015 Touchscreen Assembly Replacement, Touchscreen Assembly: 步骤 18 中的图像 2,2
    • Pry the tab just left of the joystick housing until the right corner of the touchscreen is free.
    • Pry the top of the touchscreen gently until the top middle and left side of the touchscreen is free.
  19. Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 19 中的图像 1,2 Nintendo 3DS 2015 Touchscreen Assembly Replacement: 步骤 19 中的图像 2,2
    • Gently pull up on the touchscreen from the left corner until the whole touchscreen is free.
    • Lift the touchscreen out of the device.
结论
3等其他人完成本指南。
Tyler Starr
于10/06/16注册
1,509 声望
创作了7篇指南
团队
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G6
4 名成员
创作了35篇指南
一条评论
so my new 3ds (normal size) bottom screen is pitch black (still is touch screen), if i do this procedure will it fix the problem? and if i watch a video of a new 3ds XL bottom screen being replaced would it be the same procedure as fixing a new 3ds normal size?
Dσƞυτ - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 58
过去 30 天: 223
总计 7,102
