当前版本的文档还未经巡查,您可以查看最新的已查核版本。
把设备翻到正面,并将正面对着你。
把设备的前盖移除。两个插槽位于靠近转轴的位置。
把前盖放到一边。
将塑料撬棒插入电池上部的插槽中。
向上移动撬棒把电池翘起。(其实可以直接用指甲)
Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
Reorient the device so that the power jack faces you.
Lift the SD card reader gently.
Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
Lift the SD card reader out off of the lower casing.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
