跳转到主内容
Nintendo 3DS 2015 Gamecard Reader Replacement
你所需要的
  1. Nintendo 3DS 2015 Gamecard Reader Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the two 3mm Phillips #0 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 2 中的图像 1,2 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 2 中的图像 2,2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 3 中的图像 1,3 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 3 中的图像 2,3 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 Gamecard Reader Replacement, SD Card Reader: 步骤 4 中的图像 1,1
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 5 中的图像 1,1
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 6 中的图像 1,2 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 6 中的图像 2,2
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
    Where can I buy a new SD card reader? Cant seem to find any.
    Aldair - 回复
  7. Nintendo 3DS 2015 Gamecard Reader Replacement, Lower Case: 步骤 7 中的图像 1,3 Nintendo 3DS 2015 Gamecard Reader Replacement, Lower Case: 步骤 7 中的图像 2,3 Nintendo 3DS 2015 Gamecard Reader Replacement, Lower Case: 步骤 7 中的图像 3,3
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
  8. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 8 中的图像 1,2 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 8 中的图像 2,2
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
  9. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 9 中的图像 1,3 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 9 中的图像 2,3 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 9 中的图像 3,3
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
  10. Nintendo 3DS 2015 Gamecard Reader Replacement, Gamecard Reader: 步骤 10 中的图像 1,2 Nintendo 3DS 2015 Gamecard Reader Replacement, Gamecard Reader: 步骤 10 中的图像 2,2
    • Locate the gamecard reader near the bottom right corner of the motherboard.
    • Unscrew the four 3mm Phillips #00 screws along the edge of the gamecard reader.
    • Lift the black latch on the ZIF connector along the right side of the reader using a plastic opening tool.
  11. Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 11 中的图像 1,2 Nintendo 3DS 2015 Gamecard Reader Replacement: 步骤 11 中的图像 2,2
    • Pry the ribbon cable from its socket, just left of the joystick, using the flat side of a spudger.
    • Grab the right edge of the gamecard reader and lift it out of the device, watching to make sure the ribbon cables don't snag.
结论
3等其他人完成本指南。
Tyler Starr
于10/06/16注册
1,509 声望
创作了7篇指南
团队
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G6
4 名成员
创作了35篇指南
3条评论
Where can I find this replacement Part?
Sean Taylor - 回复
Hello! Unfortunately replacement parts for this particular model are difficult to find. There seems to be some replacement parts for the XL; however, I don't think that they are the compatible with the regular 3ds. Additionally, slot replacements are sold widely; however, it would require difficult smd rework. Your best bet is to find a New 3ds 2015 that is being sold for parts on ebay that has a working gamecard reader and use that as a replacement.
Tyler Starr -
Does anyone know a replacement part link for this? I don't have the money for another one.
aiden owens - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 38
过去 30 天: 172
总计 3,950
