简介
If your games won't load replacing the gamecard reader is an option. Watch out for delicate ribbon cables in the device.
你所需要的
Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
在这个步骤中使用的工具:Tweezers$4.99
Reorient the device so that the game slot now faces you.
Remove the two rubber bumpers along the top of the device using tweezers.
Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
Locate the gamecard reader near the bottom right corner of the motherboard.
Unscrew the four 3mm Phillips #00 screws along the edge of the gamecard reader.
Lift the black latch on the ZIF connector along the right side of the reader using a plastic opening tool.
3等其他人完成本指南。
3条评论
Where can I find this replacement Part?
Hello! Unfortunately replacement parts for this particular model are difficult to find. There seems to be some replacement parts for the XL; however, I don't think that they are the compatible with the regular 3ds. Additionally, slot replacements are sold widely; however, it would require difficult smd rework. Your best bet is to find a New 3ds 2015 that is being sold for parts on ebay that has a working gamecard reader and use that as a replacement.
Does anyone know a replacement part link for this? I don't have the money for another one.
