跳转到主内容
Nintendo 3DS 2015 Circle Pad Replacement
你所需要的
  1. Nintendo 3DS 2015 Circle Pad Replacement, Battery: 步骤 1 中的图像 1,1
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 Circle Pad Replacement: 步骤 2 中的图像 1,2 Nintendo 3DS 2015 Circle Pad Replacement: 步骤 2 中的图像 2,2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 Circle Pad Replacement: 步骤 3 中的图像 1,3 Nintendo 3DS 2015 Circle Pad Replacement: 步骤 3 中的图像 2,3 Nintendo 3DS 2015 Circle Pad Replacement: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 Circle Pad Replacement, SD Card Reader: 步骤 4 中的图像 1,1
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 Circle Pad Replacement: 步骤 5 中的图像 1,1
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 Circle Pad Replacement: 步骤 6 中的图像 1,2 Nintendo 3DS 2015 Circle Pad Replacement: 步骤 6 中的图像 2,2
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
  7. Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: 步骤 7 中的图像 1,3 Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: 步骤 7 中的图像 2,3 Nintendo 3DS 2015 Circle Pad Replacement, Lower Case: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
  8. Nintendo 3DS 2015 Circle Pad Replacement: 步骤 8 中的图像 1,2 Nintendo 3DS 2015 Circle Pad Replacement: 步骤 8 中的图像 2,2
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
  9. Nintendo 3DS 2015 Circle Pad Replacement: 步骤 9 中的图像 1,3 Nintendo 3DS 2015 Circle Pad Replacement: 步骤 9 中的图像 2,3 Nintendo 3DS 2015 Circle Pad Replacement: 步骤 9 中的图像 3,3
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
  10. Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: 步骤 10 中的图像 1,3 Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: 步骤 10 中的图像 2,3 Nintendo 3DS 2015 Circle Pad Replacement, Circle Pad: 步骤 10 中的图像 3,3
    • Locate the joystick assembly near the top right corner of the motherboard.
    • Remove the two 8mm Phillips #00 screws from the back of the joystick.
    • Use the flat end of the spudger to pry off the joystick pad from its plastic housing.
  11. Nintendo 3DS 2015 Circle Pad Replacement: 步骤 11 中的图像 1,2 Nintendo 3DS 2015 Circle Pad Replacement: 步骤 11 中的图像 2,2
    • Lift the joystick pad and place it on its back. This will reveal the ribbon cable connected to the joystick pad.
    • Use the flat end of the spudger to pry up the retaining flap for the ribbon cable.
    • Lift the joystick out of the device.
结论
6等其他人完成本指南。
Michael
于10/14/16注册
173 声望
撰写一个指南
团队
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S4G6
4 名成员
创作了44篇指南
4指南评论
thank you for the help
Crichton Vance - 回复
Great, detailed tutorial. Was able to sucessfully unscrew my housing of the 3ds. I am currently fixing my circle pad.
Keyboard Smasher Gaming X - 回复
Tutorial worked wonderfully, now have a fantastic feeling circle pad on the used N3DS I picked up.
Phantom Kirby - 回复
Hi - can some steps be added to replace the actual joystick part of the circle pad? Thanks!
Daniel Griffin - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 62
过去 30 天: 331
总计 12,216
